How can I fix this unstable condition?
hi
I'm using GP2D12 Infrared sensors to control an electric lift.
I followed the recommendation which is adding a capacitor to the sensor.
But I'm having a problem that the sensor's input is extremly unstable.
I will appreciate for any comments. Thank you.
The following is the code.
#define Lift0 A3
#define Lift1 A4
#define Lift2 A5
#define front 6
#define top 7
#define Relay0 5
#define Relay1 4
int LiftValue0=0,LiftValue1=0,LiftValue2=0;
int frontValue=0,topValue=0;
int a=0,b=0,c=0;
void setup(){
  pinMode(Relay0,OUTPUT);
  pinMode(Relay1,OUTPUT);
LiftValue0=analogRead(Lift0);
LiftValue1=analogRead(Lift1);
LiftValue2=analogRead(Lift2);
frontValue=digitalRead(front);
topValue=digitalRead(top);
if(LiftValue0>300){
    a=1;}
  else{
    a=0;}
  if(LiftValue1>300){
    b=1;}
  else{
    b=0;}
  if(LiftValue2>300){
    c=1;}
   else{
     c=0;}
 if((frontValue==0)||(topValue==0)){
   if(topValue==0){
         digitalWrite(Relay1,HIGH);
         digitalWrite(Relay1,LOW);}
    if(frontValue==0){
    if((topValue==1)&&(frontValue==1)){
          if((a==1)||(b==1)||(c==1)){
              digitalWrite(Relay0,HIGH);
              digitalWrite(Relay0,LOW);}
Try to add a low pass filter. Maybe that helps
Regards
RReguera: Hi,
Regards
I will try it!
Thank you very much :)
How long are the cables to the sensor? Are they shielded? Are they running alongside high current wiring? Is there a source of electrical noise nearby? What kind of optical target material are you using for the sensor?
What exactly is the problem that needs to be fixed?
That's about as vague a statement as you could have possibly made. How do you know the sensor is unstable? What are the symptoms of the problem and where's your measurements/debugging of the problem?
Pete
MarkT:
-Approximately 90~100cm
Are they shielded?
-No they aren’t
-Only 5V
-Probably… wires from 3 sensors are inside of 17?-pipe
-Human bodies.
:slight_smile:
el_supremo: What exactly is the problem that needs to be fixed?
Pete
When I ran the code that I attached above, I could see the following symptoms.
  1. The lift(What I need to control) went up even though there weren't any targets in the range of the sensor.
  2. The lift didn't go up as against it went up (There were targets in the range)
My English is not so good to explain exactly what I'm going through =(
