Hello,
I am using Processing to send Strings to an LCD, after approx. 5 messages are received, the Arduino program appears to run out of memory and either reboots or freezes. I am not holding on to any past messages (at least intentionally), but every message seems to allocate more memory. How can I free the past message and stop my program from continuing to use more memory?
here is my arduino code:
#include <LiquidCrystal.h>
#include <WString.h>
#define CHARACTERSPERLINE 20
#define LCDLINES 4
#define MAXLINES 10
String heldText = String(CHARACTERSPERLINE*MAXLINES);
int received = 0;
LiquidCrystal lcd(7,8,9,10,11,12);
int buzzerPin = 3;
// start serial port at 9600 bps:
//pinMode(2, INPUT); // digital sensor is on digital pin 2
lcd.begin(CHARACTERSPERLINE,LCDLINES);
//lcd.autoscroll();
establishContact(); // send a byte to establish contact until receiver responds
// heldText = "returns a new string that is a part of the original string. When using the endIndex parameter, the string between beginIndex and endIndex -1 is returned.";
//heldTextToLCD();
// if we get a valid byte, read analog ins:
if (Serial.available() > 0)
// get incoming byte:
handleIncomingChars();
// delay 10ms to let the ADC recover:
delay(10);
void establishContact() {
while (Serial.available() <= 0) {
Serial.println("0,0,0"); // send an initial string
delay(300);
void handleIncomingChars() {
// read the incoming data as a char:
char inChar = Serial.read();
if(inChar=='\n' || inChar == '\r')
lcd.clear();
lcd.home();
heldTextToLCD();
heldText = "";
//I HAVE ALSO TRIED THE FOLLOWING TWO LINES
// free(heldText);
// heldText = String(CHARACTERSPERLINE*MAXLINES);
// if you're not at the end of the string, append
// the incoming character:
if (heldText.length() < (CHARACTERSPERLINE*MAXLINES))
heldText.append(inChar);
// empty the string by setting it equal to the inoming char:
heldText = inChar;
void heldTextToLCD()
Serial.println(heldText);
int numLines = heldText.length() / CHARACTERSPERLINE;
//String lastFragment = "";
int remainingLength = heldText.length();
lcd.clear();
int currentIndex = 0;
int i=0;
while(remainingLength>0 || i > MAXLINES)
if(i%LCDLINES==0)
lcd.clear();
lcd.setCursor(0,i%LCDLINES);
String line = String(32);//lastFragment;
int lengthToTake = CHARACTERSPERLINE;
if(remainingLength < CHARACTERSPERLINE)
lengthToTake = remainingLength;
line.append(heldText.substring(currentIndex,currentIndex+lengthToTake));
delay(10);
currentIndex += lengthToTake;
delay(100);
lcd.print(line);
delay(2000);
i++;
remainingLength = heldText.length() - currentIndex;
Serial.println("done");
delay(10);
Serial.println(availableMemory());
int availableMemory() {
int size = 1024; // Use 2048 with ATmega328
byte *buf;
while ((buf = (byte *) malloc(--size)) == NULL)
free(buf);
return size;
As you can see I am using a little "availableMemory()" snippet I found, after each message I am printing that out and the number gets smaller until crashing.
I posted this on the software interfacing a couple days ago, but have since realized the issue likely isn't processing.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1255733236
I would really appreciate some help with this, thanks in advance.
