How can I generate 8MHz clock using timers or PWM with my Arduino Leonardo?
Hi, I'm trying to generate 8MHz clock from the arduino to connect it to an OV7670 camera sensor on XCLK pin. I'm trying to do it using the timer 1, but the maximum frequency I get is approximately 41kHz?
Here is my code:
const int led=10;
Input Frequency -> CLK=16MHz
Timer Resolution = (1 / (Input Frequency / Prescale)) = (Prescale / Input Frequency)
Prescaler Value | Resolution at 16MHz
              1 |  62.5nS
              8 |  0.6uS
             64 |  4uS
            256 |  16uS
           1024 |  64uS
Target Timer Count = (1 / (Target Frequency*2)) / (Prescale / Input Frequency) - 1
                   = (Target Period / 2) / Timer Resolution - 1
If: Target Period = 125nsec.  ->  Target frequency = 8MHz
With prescaler = 1
Target Timer Count = (125nS/2)/62.5nS - 1 = 0
#define TMR1 0    //for 8MHz
ISR(TIMER1_COMPA_vect)
  digitalWrite(led, digitalRead(led)^1);
  pinMode(led, OUTPUT);
  //TIMER1 (16 bits) in mode CTC
  TCCR1B |= (1 << CS10);  //selecting prescaler 0b001 (Tclk/1)
  TCCR1B &= ~((1<<CS12) | (1<<CS11));    // turn off CS12 and CS11 bits
  TCCR1B |= (1 << WGM12); // Configure timer 1 for CTC mode
  TCCR1A &= ~((1<<WGM11) | (1<<WGM10));
  OCR1A = TMR1;
  TIMSK1 |= (1 << OCIE1A); // Enable CTC interrupt
  sei();    //Enable global interrupts
void loop(){}
I'm guessing that the instruction in the interrupt routine is taking too long.
Thanks.
You're trying to generate an output frequency half the clock frequency of the controller, using an interrupt.
That simply cannot work.
And how can I do it then?
Or do you mean that it can not be done?
Can I configure the PWM to get that frequency?
looked at http://forum.arduino.cc/index.php/topic,22384.0.html
code that should set pin 3 to 1MHz - it uses timer2 and the normal analogWrite function for pins 3 and 11 won't be available if you do this. This may help.
#define PWMout 3
void setup ()
TCCR2A = 0xB3 ; // fast PWM with programmed TOP val
TCCR2B = 0x09 ; // divide by 1 prescale
TCNT2 = 0x00 ;
OCR2A = 0x0F ; // TOP = 15, cycles every 16 clocks
OCR2B = 0x07 ; // COMP for pin3
pinMode (PWMout, OUTPUT) ;
Well Ixguru thanks for the TIP! I checked out the datasheet and configured the TIMER1 in TOP mode and Toggle mode .
Here I post my code. It works super OK!!!
#include <avr/interrupt.h>
#include <avr/io.h>
              1 |  62.5nS
              8 |  0.6uS
             64 |  4uS
            256 |  16uS
           1024 |  64uS
Target Timer Count = (1 / (Target Frequency * 2)) / (Prescale / Input Frequency) - 1
If: Target Period = 125nseg.  ->  Target frequency = 8MHz
With prescaler = 1
#define TMR1 0    //for 8MHz: TMR1 = 0 , for 10kHz: TMR1 = 799
  pinMode(9, OUTPUT);
  //TIMER1 (16 bits) in mode TOP
  TCCR1A |= ((1<<WGM11) | (1<<WGM10));  //Configure timer 1 for TOP mode (with TOP = OCR1A)
  TCCR1B |= ((1<<WGM13) | (1<<WGM12));
  TCCR1A |= (1 << COM1A0); // Enable timer 1 Compare Output channel A in toggle mode
  TCCR1A &= ~(1 << COM1A1);
  TCNT1 = 0;
  OCR1A = TMR1;
Thanks for sharing out your code - spirit of open source :). Basically to use Fast PWM mode, setting TOP value 0. How did you verify you got the desired clock? by using arduinoscope? curious.
I'm using an oscilloscope. That's how i verified the frequency.
