How can I get accurate value of temperature and humidity from DHT11 and NodeMCU
I would like to measure the temperature and humidity from DHT11 sensor and NodeMCU.
To do so, I made some code by using two libraries.
But none of these can give me an accurate number of humidity and temperature value.
All I can get an output are like followings.
Temperature = 21.0000
Humidity = 48.0000
Please give me a hint to upgrade my code.
First code
#include <DHTesp.h>
DHTesp dht;
void setup(){
pinMode(0, INPUT);
dht.setup(0, DHTesp::DHT11);
void loop(){
Serial.print("Temperature = ");
Serial.println(dht.getTemperature(), 4);
Serial.print("Humidity = ");
Serial.println(dht.getHumidity(), 4);
Seconde code
#include <DHT.h>
DHT dht(0, DHT11);
pinMode(0, INPUT);
dht.begin();
float humidity = dht.readHumidity();
float temp = dht.readTemperature();
Serial.println(humidity);
What is your "accuracy" requirement and is it within the capability of the DHT11 device?
My English expression is not so accurate.
What I want to get is for example 21.8 Deg and 48.3% Hum.
But DHT11 just return 21.0000 48.0000 only.
It looks like DHT11 returns integer values instead of float values.
gfvalvo:
What I want to get is float value return, like I wrote following reply
does it have to be accurate as
21.8 43.7
or
28.76 43.69
or
28.758 43.687
there should be a lot of demo-code in the internet of just reading a DHT11
what results do you get if you use on eof these demo-codes?
best regards Stefan
