I’ve been struggling with this for a couple of months now, and I’m wondering what could be the problem, and how could I solve it. I have the newest midi library!
#include <MIDI.h>
int potPin = A0;
int analogValue = 0;
int lastAnalogValue = 128;
MIDI.begin(4);
// 115200 hairless MIDI
int analogValue = analogRead(A0)/8;
if ((analogValue-lastAnalogValue) > 1 || (analogValue-lastAnalogValue) < -1) {
// value changed?
if (analogValue != lastAnalogValue) {
// send serial value (ControlNumber 1, ControlValue = analogValue, Channel 1)
// more info: http://arduinomidilib.sourceforge.net/a00001.html
MIDI.sendControlChange(1, analogValue, 1);
lastAnalogValue = analogValue;
and the error that i get is:
Arduino: 1.5.8 (Windows 7), Board: "Arduino Leonardo"
sketch_dec09b.ino: In function 'void setup()':
sketch_dec09b.ino:9:3: error: 'MIDI' was not declared in this scope
sketch_dec09b.ino: In function 'void loop()':
sketch_dec09b.ino:23:11: error: 'MIDI' was not declared in this scope
Error compiling.
enabled in File > Preferences.
"The default MIDI object has been removed, so you will need to create it using one of the following macros:
For straightforward compatibility with sketches written with v4.1 and older:
MIDI_CREATE_DEFAULT_INSTANCE();
(You probably want to use Serial1 on the Leonardo since Serial goes only to USB.)
Thanks John! But I would like some more help, because I don’t get any midi data, and I’ve changed my code a little
#include <MIDI.h>
int potPin = A0;
MIDI.begin(1);
// value changed?
Hello again John! I am using hairless-midiserial to convert serial messages and loopMIDI to make a virtual MIDI port(I have also tried this with LoopBe1). I have it set up like this:
I have used this as a reference!
