How can I increase the sample rate?
Hi all,
I'm using an Arduino Uno and an analog accelerometer with a 16-bit ADC to record vibrations. I'm also writing the data directly to an SD card. I want to increase the sampling rate but I'm not sure what the limiting factor is. I've got the delay in my loop set at 10 (see below) so I was expecting it to sample at 100Hz. However I'm only getting around 20 readings of the x, y and z accelerations per second. Can anyone suggest what I could do to improve this?
#include <SPI.h>
#include <SD.h>
#include <SoftwareSerial.h>
#include <Wire.h>
#include <Adafruit_ADS1015.h>
  Adafruit_ADS1115 ads;           // Construct a 16-bit ADS1115 address
  float x, y, z;
  const int chipSelect = 10;
  float time;
Serial.print("Initializing SD card...");
    if (!SD.begin(chipSelect)) {
      Serial.println("Card failed, or not present");
      return;
  Serial.println("card initialized.");
  File dataFile = SD.open("datalog.csv", FILE_WRITE);
  dataFile.println("Next batch:");
  dataFile.println(",");
  dataFile.close();
  ads.begin();
  time = micros();
  float secs = time/1000000;
  x = ads.readADC_SingleEnded(3);
  y = ads.readADC_SingleEnded(2);
  z = ads.readADC_SingleEnded(1);
    dataFile.print(secs,7);
    dataFile.print(",");
    dataFile.print(x,7);
    dataFile.print(y,7);
    dataFile.println(z,7);
    dataFile.close();
  //delay(10);
You could try not opening and closing the file every time through loop()
Ok, thanks, so should I try opening and closing the file with subroutines? Not really sure how to implement that, any examples I could look at?
Why not open the file in setup() and only close it when you need to?
Groove:
Because I'm not sure how long I need it to run for so I'm just ejecting the SD card when I've got the data I want. Don't know what will happen if I eject with the file open, guess it's worth trying...
Why do this?
Just store the micros(), it and the float are both 4 bytes, not gaining anything by dividing. Let the PC do that.
"Because I'm not sure how long I need it to run for so I'm just ejecting the SD card when I've got the data I want.'
So add reading of a button press, when you see it close the file for a graceful end of write and then pull the card.
CrossRoads:
Thanks, good shout
As for the button press, would it look something like this:
  float x, y, z;
  const int buttonPin = 6;
  int buttonState = 0;
  pinMode(buttonPin, INPUT);
  ads.begin();
  buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH){
      dataFile.close();
      else {
         dataFile.print(micros,7);
         delay(10);
Cheers for the help, really appreciate it!
