How can I insert the password.keypad example in my code ?
I have this code
#include <Wire.h>
#include <PCFCrystal.h>
#include <i2ckeypad.h>
#include <Password.h>
Password password = Password( "1234" );
byte buffer = 0;
PCFCrystal lcd(B00100000, B00010000, B00000001, B00000010, B00000100, B00001000, 0x39, &buffer);
const int buttonPin = 2;
int buttonState = 0;
#define ROWS 4
#define COLS 4
#define PCF8574_ADDR 0x38
i2ckeypad kpd = i2ckeypad(PCF8574_ADDR, ROWS, COLS);
  Wire.begin();
    lcd.begin(16, 2);
  lcd.setCursor(0,0);
    pinMode(buttonPin, INPUT);
      kpd.init();
  Serial.print("Testing keypad/PCF8574 I2C port expander arduino lib\n\n");
  buttonState = digitalRead(buttonPin);
     char key = kpd.get_key();
  if(key) {
        switch (key)
      case '5':
        lcd.setCursor(0,0);
    lcd.print("5                     ");
      case '9':
       lcd.setCursor(0,0);
    lcd.print("9                       ");
      default:
        Serial.println(key);
  void keypadEvent(KeypadEvent eKey){
And i need to I connect this code
|| @file PasswordKeypad.pde
|| @version 1.0
|| @author Alexander Brevig
|| @contact alexanderbrevig@gmail.com
|| @description
|| | A simple password application that uses a keypad as input source.
//http://www.arduino.cc/playground/uploads/Code/Password.zip
//http://www.arduino.cc/playground/uploads/Code/Keypad.zip
#include <Keypad.h>
byte rows = 4; //four rows
byte cols = 4; //four columns
byte rowPins[] = {2,3,4,5}; //connect to the row pinouts of the keypad
byte colPins[] = {6,7,8,9}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad(rowPins,colPins,rows,cols);
const byte ledPin = 13;
void setup(){
  pinMode(ledPin, OUTPUT);      // sets the digital pin as output
  digitalWrite(ledPin, HIGH);   // sets the LED on
  keypad.addEventListener(keypadEvent); //add an event listener for this keypad
void loop(){
  keypad.getKey();
//take care of some special events
  switch (eKey){
    case '*': guessPassword(); break;
    case '#': password.reset(); break;
	default:
		password.append(eKey);
void guessPassword(){
	if (password.evaluate()){
		digitalWrite(ledPin,HIGH);
	}else{
		digitalWrite(ledPin,LOW);
When I have insert this ( void keypadEvent(KeypadEvent eKey){)
I have the error
sorry I’am new in Arduino
I have the error
sorry I'am new in Arduino
That error is only correctable with experience.
Perhaps you meant a different error?
need I use the keypad.h ? i use the I2Ckeypad.h can I insert the password.h ?Is it possible?
Use the one that goes with the keypad you have. If you have an I2C keypad, use the I2Ckeypad library. Otherwise, don't.
Yes and yes.
I try to compile this two code but when I insert ( keypad.addEventListener(keypadEvent); ) I have this error
i2c_keypadand_lcd.cpp: In function 'void setup()':
i2c_keypadand_lcd:30: error: 'keypad' was not declared in this scope
i2c_keypadand_lcd:30: error: 'keypadEvent' was not declared in this scope
If,I understood correctly it is not included in I2ckeypad.h But it included in keypad.h please can you help me?
? tried to I edit the I2Ckeypad.h but I didn't I managed it . have someone any idea ? what must I try?
Did you achieve this? I want to do exactly what you wanted… <i2ckeypad.h> & <Password.h>
Good I speak two languages, I found the solution in Spanish… The only problem with the Library is 1.0 compatibility. You need to change in Password.h #include <WProgram.h> for #include <Arduino.h> and the library works great!
