How can i interface this with lcd display code(water flow sensor)
Liquid flow rate sensor -DIYhacking.com Arvind Sanjeev
Measure the liquid/water flow rate using this code.
Connect Vcc and Gnd of sensor to arduino, and the
signal line to arduino digital pin 2.
byte statusLed    = 13;
byte sensorInterrupt = 0;  // 0 = digital pin 2
byte sensorPin       = 2;
// The hall-effect flow sensor outputs approximately 4.5 pulses per second per
// litre/minute of flow.
float calibrationFactor = 4.5;
volatile byte pulseCount;
float flowRate;
unsigned int flowMilliLitres;
unsigned long totalMilliLitres;
unsigned long oldTime;
// Initialize a serial connection for reporting values to the host
// Set up the status LED line as an output
pinMode(statusLed, OUTPUT);
digitalWrite(statusLed, HIGH);  // We have an active-low LED attached
pinMode(sensorPin, INPUT);
digitalWrite(sensorPin, HIGH);
pulseCount        = 0;
flowRate          = 0.0;
flowMilliLitres   = 0;
totalMilliLitres  = 0;
oldTime           = 0;
// The Hall-effect sensor is connected to pin 2 which uses interrupt 0.
// Configured to trigger on a FALLING state change (transition from HIGH
// state to LOW state)
attachInterrupt(sensorInterrupt, pulseCounter, FALLING);
* Main program loop
 if((millis() - oldTime) > 1000)    // Only process counters once per second
  // Disable the interrupt while calculating flow rate and sending the value to
  // the host
  detachInterrupt(sensorInterrupt);
  // Because this loop may not complete in exactly 1 second intervals we calculate
  // the number of milliseconds that have passed since the last execution and use
  // that to scale the output. We also apply the calibrationFactor to scale the output
  // based on the number of pulses per second per units of measure (litres/minute in
  // this case) coming from the sensor.
  flowRate = ((1000.0 / (millis() - oldTime)) * pulseCount) / calibrationFactor;
  // Note the time this processing pass was executed. Note that because we've
  // disabled interrupts the millis() function won't actually be incrementing right
  // at this point, but it will still return the value it was set to just before
  // interrupts went away.
  oldTime = millis();
  // Divide the flow rate in litres/minute by 60 to determine how many litres have
  // passed through the sensor in this 1 second interval, then multiply by 1000 to
  // convert to millilitres.
  flowMilliLitres = (flowRate / 60) * 1000;
  // Add the millilitres passed in this second to the cumulative total
  totalMilliLitres += flowMilliLitres;
  unsigned int frac;
  // Print the flow rate for this second in litres / minute
  Serial.print("Flow rate: ");
  Serial.print(int(flowRate));  // Print the integer part of the variable
  Serial.print("L/min");
  Serial.print("\t");  // Print tab space
  // Print the cumulative total of litres flowed since starting
  Serial.print("Output Liquid Quantity: ");
  Serial.print(totalMilliLitres);
  Serial.println("mL");
Serial.print(totalMilliLitres/1000);
Serial.print("L");
  // Reset the pulse counter so we can start incrementing again
  pulseCount = 0;
  // Enable the interrupt again now that we've finished sending output
Insterrupt Service Routine
void pulseCounter()
// Increment the pulse counter
pulseCount++;
Please, use code tags.
Which LCD? Have you made an attempt to include an LCD to your code?
Read the how to use this forum sticky to see how to properly post code in code tags.
Im planning 16 x 2 nope
Do you have an LCD? Have you managed to make the LCD work on its own with an example from a liquid crystal library? My favorite LCD library is the hd44780 library.
Documentation here.
First I'd try an example for the LCD.
