Hey guys,
You may recall that recently I was having an issue with my circuit where my leds would dim when my servos activated, and occasioanlly my atmega would reset because my batteries were unable to supply enough current.
One of the solutions I'd briefly considered was using a resistor to limit the current. But at the time, I didn't explore this option further. Well, I recently revisited it, and determined that at 4.8v, I was gonna need pretty large resistors if I was planning to feed 1A to my two servos, and resistors that can hande that much current seem hard to find on Mouser, and space is really limited with this project. So I wondered is maybe there wasn't some other way to limit the current to the servos.
So I've been doing some research in that area, and it seems like it's possible to limit current using a diode or two, a resitor, and a transistor. But I haven't been able to find a source which explains how to choose the right transistor, resistor, and diodes. Because of this, I'm not even sure if this is a viable solution.
I really think I need to solve this problem by limiting the current to the servos rather than by using two voltage regulators and two batteries, because I need to fit like four chips, 8 dip switches, two trimpots, a bunch of molex connecotrs, and whatever resistors and capacitors I need on a board which is like 2"x4", and an extra voltage regulator and another ser of batteries is just gonna make things even tigther. Plus I'm hoping to integrate a dac and an amp onto the board as well and I don't know if I'm gonna need a seperate power source for those, so I'm hoping I can at least power the rest of the board and servos with the one power source.
Maybe I don't even need a transistor though. It might be that I have done my calculations on how much power my resistor needs to dissipate incorrectly. It seems a bit odd to me that the lower the value in ohms I have for my resistor the bigger the resistor I need. I mean I don't need a huge wire to conduct 1 amp, so why would I need a super large resistor?
Yet when I use the ohms law calculator:
http://www.the12volt.com/ohm/page2.asp
...and input 4.8v and 1 amp, I get 4.8ohms for my resistor value. And if I then put in 1 amp and 4.8 ohms I get 4.8 watts. Does that mean I need a resistor that can handle 4.8 watts? Or is that simply the watts flowing through it, and I need to do some other calculation to determine how much of that power it's actually dissipating as heat? And how do I calculate that?
