how can i make a function
im workin on rc car project. and ive make a code to control the car by mobile via bluetooth module.
ive made a simple code and it worked well but when i tried to make it like a function and call it in void loop. it didnt work and i tried to read alot of examples but didnt solve anythin ...... i need help on that
sketch_feb09a_bluetooth.ino (1.6 KB)
Your code like I should have been posted. (Please have a look at Read this before posting a programming question.)
char junk;
String state = "";
  Serial.begin(9600);            // set the baud rate to 9600, same should be of your Serial Monitor
  pinMode(13, OUTPUT);            //A1
  pinMode(12, OUTPUT);             //A2
  pinMode(11, OUTPUT);             //B1
  pinMode(10, OUTPUT);             //B2
  if (Serial.available())
    while (Serial.available())
      char inChar = (char)Serial.read();                            //read the input
      state = inChar;                                 //make a string of the characters coming on serial
    Serial.println(state);
    while (Serial.available() > 0)
      junk = Serial.read() ;              // clear the serial buffer
    if (state == "f")
    {                                  //in case of 'f' turn DC motor forward
      car_forward();
    else if (state == "b")           //in case of 'b' turn DC motor backword
      car_backword();
    else if (state == "l")              //in case of 'l' turn wheels to left
      car_left();
    else if (state == "r")              //in case of 'r' turn wheels to right
      car_right();
    else if (state == "s")
      motor_stop();
void motor_stop()
  digitalWrite(13, 0);
  digitalWrite(12, 0);
  digitalWrite(11, 0);
  digitalWrite(10, 0);
void car_forward()
  digitalWrite(13, 1);
void car_backword()
  digitalWrite(12, 1);
void car_right()
  digitalWrite(11, 1);
void car_left()
  digitalWrite(10, 1);
The comment does not match the code.
it didnt work
Can you expand on that? I loaded your code to an Uno, put prints in each of the functions and it seems to work fine as far as executing the proper functions when b, f, s, l and r are sent from serial monitor. I don't have anything connected to the output pins, though. Serial monitor set with no line endings.
char junk;
String state = "";
    if (state == "f")
      car_forward();
      car_backword();
      car_left();
      car_right();
      motor_stop();
void motor_stop()
  Serial.println("stop");
void car_forward()
  Serial.println("fwd");
void car_backword()
  Serial.println("back");
void car_right()
  Serial.println("rt");
void car_left()
  Serial.println("lf");
wat means by Serial monitor set with no line endings.
To the left of the baud rate setting box is a box where you can set serial monitor to send a carriage return/line feed or just line feed or nothing at the end of characters sent when the send button is pushed to send data from serial monitor.
