How can I make a if statement that uses if something happens after something?
So I want to make a project where it tells you from which direction something came from and is going. I have two IR sensors, one for the left and one for the right. The idea was to have the code be if (digitalRead(12) == LOW && digitalRead(13) == LOW) {
(turn on lights in that direction)
Unfortunately that does not get me the outcome that is desirable.
So I was wondering how I could make a if statement that only works if say the right sensor goes off after the left one.
Save the time (use millis()) when each sensor is activated. Then compare the times to know which one was first.
Welcome to the forum
We are going to know a lot more details before providing any answers. Start by posting your full sketch that does not do what you want. Help us by giving the pins names rather than using anonymous numbers and use code tags when you post the code
check which sensor is on first
if (digitalRead(left) == LOW &&  digitalRead(right) == HIGH) first ='l';
else if (digitalRead(right) == LOW &&  digitalRead(right) == HIGH) first ='r';
if (digitalRead(left) == LOW &&  digitalRead(left) == LOW)
  Serial.println(F("first was ")); Serial.println(first);
or vice versa, which one is first off...
here is the full code:
//sensors
int right = 12;
int left = 13;
//lights
pinMode(53,OUTPUT); // rightmost light
pinMode(51,OUTPUT);
pinMode(49,OUTPUT);
pinMode(47,OUTPUT);
pinMode(45,OUTPUT);
pinMode(43,OUTPUT);
pinMode(41,OUTPUT);
pinMode(39,OUTPUT);
pinMode(37,OUTPUT); // leftmost light
//IR sensors
pinMode(13,INPUT);
pinMode(12,INPUT);
 if (digitalRead(right) == LOW && digitalRead(left) == LOW ) { //this is meant to only be set off if the left sensor goes off after the right
 //turn the lights on from right to left
 digitalWrite(53,HIGH);
 digitalWrite(53,LOW);
 digitalWrite(51,HIGH);
  digitalWrite(51,LOW);
 digitalWrite(49,HIGH);
  digitalWrite(49,LOW);
 digitalWrite(47,HIGH);
  digitalWrite(47,LOW);
 digitalWrite(45,HIGH);
  digitalWrite(45,LOW);
 digitalWrite(43,HIGH);
  digitalWrite(43,LOW);
 digitalWrite(41,HIGH);
  digitalWrite(41,LOW);
 digitalWrite(39,HIGH);
   digitalWrite(39,LOW);
    digitalWrite(37,HIGH);
     digitalWrite(37,LOW);
 else if (digitalRead(left) == LOW && digitalRead(right) == LOW) { // this is only meant to be set off if the right sensor goes off after the left
  //turn lights on from left to right
 else {
  //keep lights off
Hello wanderingtraveler
Check and test this sketch.
I´ve made some mods wrt the if() conditions.
All untested.
//sensors
int right = 12;
int left = 13;
//lights
  pinMode(53, OUTPUT); // rightmost light
  pinMode(51, OUTPUT);
  pinMode(49, OUTPUT);
  pinMode(47, OUTPUT);
  pinMode(45, OUTPUT);
  pinMode(43, OUTPUT);
  pinMode(41, OUTPUT);
  pinMode(39, OUTPUT);
  pinMode(37, OUTPUT); // leftmost light
  //IR sensors
  pinMode(13, INPUT);
  pinMode(12, INPUT);
  if (digitalRead(right) == HIGH && digitalRead(left) == LOW ) //this is meant to only be set off if the left sensor goes off after the right
    digitalWrite(53, HIGH);
    digitalWrite(53, LOW);
    digitalWrite(51, HIGH);
    digitalWrite(51, LOW);
    digitalWrite(49, HIGH);
    digitalWrite(49, LOW);
    digitalWrite(47, HIGH);
    digitalWrite(47, LOW);
    digitalWrite(45, HIGH);
    digitalWrite(45, LOW);
    digitalWrite(43, HIGH);
    digitalWrite(43, LOW);
    digitalWrite(41, HIGH);
    digitalWrite(41, LOW);
    digitalWrite(39, HIGH);
    digitalWrite(39, LOW);
    digitalWrite(37, HIGH);
    digitalWrite(37, LOW);
  if (digitalRead(left) == LOW && digitalRead(right) == HIGH)  // this is only meant to be set off if the right sensor goes off after the left
    //keep lights off
unfortunately that code did not work for it
These are the same condition ??
As a state machine
if state = idle
  if right trigger
    state := right
  else if left trigger
     state := left
else if state = right
  if left trigger
  do left actions
  state := idle
else // must be left state by elimination
  if right trigger
  do right actions
  state := idle
or similar
Are you two timing us writing code somewhere else :face_with_raised_eyebrow:
I'm doing assignment like K&R should have done. :wink:
