I've been trying to make this IR Alarm which should sound for 5 seconds but don't know how to start.
#define led 4 // led at pin 4
#define buzzer 5 // buzzer at pin 5
#define sensor 6 // ir sensor at pin 6
int sound=400; // set buzzer sound
pinMode(sensor,INPUT);
pinMode(led,OUTPUT);
pinMode(buzzer,OUTPUT);
int detect=digitalRead(sensor); // read status of sensor
if(detect==HIGH) // if sensor detects obstacle
digitalWrite(led,LOW); // led OFF
noTone(buzzer); // buzzer OFF
else{
digitalWrite(led,HIGH);
tone(buzzer,sound);
delay(300);
To determine if your buzzer is active or not;
Connect it directly to the 5V and gnd supply, if it buzzes or beeps then it is an active buzzer and you only need to activate the controller output to make it work.
If it just makes a single tick noise. then it is not an active buzzer and you will need to use tone or similar to quickly switch it on/off/on/off so it sounds like a beep or buzz.
