Hi all,
At first, I created easy project for measuing dust PM2.5 in the air by ESP8266 "NodeMCU E-12" with dust sensor. Then I buy PM2.5 Infrared Dust Sensor DSM501A from AliExpress below;
I try to search datasheet for my sensor, the below datasheet nearly my sensor model.
I connect Sensor with NodeMCU E-12 bellow:
Sensor Pin #1 not use
Sensor Pin #2 -> NodeMCU E-12 "D4"
Sensor Pin #3 -> NodeMCU E-12 "Vin"
Sensor Pin #4 -> NodeMCU E-12 "D6"
Sensor Pin #5 -> NodeMCU E-12 "GND"
I use my source code below:
int pin2 = D6;
int pin1 = D4;
unsigned long duration1;
unsigned long duration2;
unsigned long starttime;
unsigned long sampletime_ms = 3000; //sampe 1s ;
unsigned long lowpulseoccupancy1 = 0;
unsigned long lowpulseoccupancy2 = 0;
float ratio1 = 0;
float ratio2 = 0;
float concentration1 = 0;
float concentration2 = 0;
pinMode(D4, INPUT);
pinMode(D6, INPUT);
starttime = millis(); //get the current time;
duration1 = pulseIn(pin1, LOW);
duration2 = pulseIn(pin2, LOW);
lowpulseoccupancy1 = lowpulseoccupancy1 + duration1;
lowpulseoccupancy2 = lowpulseoccupancy2 + duration2;
if ((millis() - starttime) > sampletime_ms) //if the sampel time == 30s
ratio1 = lowpulseoccupancy1 / (sampletime_ms * 10.0); // Integer percentage 0=>100
concentration1 = 1.1 * pow(ratio1, 3) - 3.8 * pow(ratio1, 2) + 520 * ratio1 + 0.62; // using spec sheet curve
ratio2 = lowpulseoccupancy2 / (sampletime_ms * 10.0); // Integer percentage 0=>100
concentration2 = 1.1 * pow(ratio2, 3) - 3.8 * pow(ratio2, 2) + 520 * ratio2 + 0.62; //
Serial.println("PM10");
Serial.print("concentration1 = ");
Serial.print(concentration1);
Serial.print(" pcs/0.01cf - ");
Serial.print("concentration2 = ");
Serial.print(concentration2);
if (concentration1 < 1000) {
Serial.println("CLEAN");
if (concentration1 > 1000 && concentration1 < 10000) {
Serial.println("GOOD");
if (concentration1 > 10000 && concentration1 < 20000) {
Serial.println("ACCEPTABLE");
if (concentration1 > 20000 && concentration1 < 50000) {
Serial.println("HEAVY");
if (concentration1 > 50000) {
Serial.println("HAZARD");
The sample output from Serial Monitor is below:
PM10
concentration1 = 360.14 pcs/0.01cf - concentration2 = 0.62 pcs/0.01cf - CLEAN
PM10
concentration1 = 102.13 pcs/0.01cf - concentration2 = 0.62 pcs/0.01cf - CLEAN
PM10
concentration1 = 529.45 pcs/0.01cf - concentration2 = 0.62 pcs/0.01cf - CLEAN
I am not sure,
Does "pcs/0.01cf" value equal to "microgram/m3"? ![]()
If not, How can I measure value from dust sensor 'DSM501A' in 'microgram/m3'?
Please advise me.
