how can i multiple io read and multiple write io
İ am using the arduino mega in my project. İm using 2 arduino mega n 1 has about 32 input and the other has 32 output. Is it possible to see at the same time all inputs? And can i write 32 inputs positions to outputs same time? and how?.i used pic before.there are porta or portb portc.
you an address the registers directly through port manipulation but only up to 8 pins at a time, same as a pic I believe.
thanks
If you look in variants/mega/pin_arduino.h (somewhere inside your Arduino distribution) you'll see the pin mapping to ports and bit positions:
const uint8_t PROGMEM digital_pin_to_port_PGM[] = { // PORTLIST // ------------------------------------------- PE , // PE 0 ** 0 ** USART0_RX PE , // PE 1 ** 1 ** USART0_TX PE , // PE 4 ** 2 ** PWM2 PE , // PE 5 ** 3 ** PWM3 PG , // PG 5 ** 4 ** PWM4 PE , // PE 3 ** 5 ** PWM5 PH , // PH 3 ** 6 ** PWM6 PH , // PH 4 ** 7 ** PWM7 PH , // PH 5 ** 8 ** PWM8 PH , // PH 6 ** 9 ** PWM9 PB , // PB 4 ** 10 ** PWM10 PB , // PB 5 ** 11 ** PWM11 PB , // PB 6 ** 12 ** PWM12 PB , // PB 7 ** 13 ** PWM13 PJ , // PJ 1 ** 14 ** USART3_TX PJ , // PJ 0 ** 15 ** USART3_RX PH , // PH 1 ** 16 ** USART2_TX PH , // PH 0 ** 17 ** USART2_RX PD , // PD 3 ** 18 ** USART1_TX PD , // PD 2 ** 19 ** USART1_RX PD , // PD 1 ** 20 ** I2C_SDA PD , // PD 0 ** 21 ** I2C_SCL PA , // PA 0 ** 22 ** D22 PA , // PA 1 ** 23 ** D23 PA , // PA 2 ** 24 ** D24 PA , // PA 3 ** 25 ** D25 PA , // PA 4 ** 26 ** D26 PA , // PA 5 ** 27 ** D27 PA , // PA 6 ** 28 ** D28 PA , // PA 7 ** 29 ** D29 PC , // PC 7 ** 30 ** D30 PC , // PC 6 ** 31 ** D31 PC , // PC 5 ** 32 ** D32 PC , // PC 4 ** 33 ** D33 PC , // PC 3 ** 34 ** D34 PC , // PC 2 ** 35 ** D35 PC , // PC 1 ** 36 ** D36 PC , // PC 0 ** 37 ** D37 PD , // PD 7 ** 38 ** D38 PG , // PG 2 ** 39 ** D39 PG , // PG 1 ** 40 ** D40 PG , // PG 0 ** 41 ** D41 PL , // PL 7 ** 42 ** D42 PL , // PL 6 ** 43 ** D43 PL , // PL 5 ** 44 ** D44 PL , // PL 4 ** 45 ** D45 PL , // PL 3 ** 46 ** D46 PL , // PL 2 ** 47 ** D47 PL , // PL 1 ** 48 ** D48 PL , // PL 0 ** 49 ** D49 PB , // PB 3 ** 50 ** SPI_MISO PB , // PB 2 ** 51 ** SPI_MOSI PB , // PB 1 ** 52 ** SPI_SCK PB , // PB 0 ** 53 ** SPI_SS PF , // PF 0 ** 54 ** A0 PF , // PF 1 ** 55 ** A1 PF , // PF 2 ** 56 ** A2 PF , // PF 3 ** 57 ** A3 PF , // PF 4 ** 58 ** A4 PF , // PF 5 ** 59 ** A5 PF , // PF 6 ** 60 ** A6 PF , // PF 7 ** 61 ** A7 PK , // PK 0 ** 62 ** A8 PK , // PK 1 ** 63 ** A9 PK , // PK 2 ** 64 ** A10 PK , // PK 3 ** 65 ** A11 PK , // PK 4 ** 66 ** A12 PK , // PK 5 ** 67 ** A13 PK , // PK 6 ** 68 ** A14 PK , // PK 7 ** 69 ** A15 };
