Let's say I serial print "hello", How to serial read only the second letter "e" in "Hello"?
Any Ideas?
Any Ideas?
Do a read, do nothing with that character, then do another read maybe?
But having read your question again, if you're doing a serial print of something (which is outbound so to speak) what do you mean by doing a read of that, which is inbound?
if you print it's gone. The read can only be done on the destination device. Is that what you are asking for?
serial print = gives provided output in serial monitor
serial read = reads all the values outputted in the serial monitor
Is this what u asked for?
Serial.read() reads one byte (packed into the LSB of an int) coming into the Serial port, whatever it's connected to or returns -1 if there was nothing to read
Could this be an x-y problem? Perhaps @homechennai you could provide some detail of what you're actually trying to do.
assuming you mean the 2nd character of any "line" received
e - hello
h - charlie
u - duck
char buf [80];
void
loop (void)
if (Serial.available()) {
int n = Serial.readBytesUntil ('\n', buf, sizeof(buf)-1);
buf [n] = '\0';
Serial.print (buf [1]);
Serial.print (" - ");
Serial.println (buf);
void
setup (void)
Serial.begin (9600);
//6=RightPWM
//5=LeftPWM
//10=RightControlCW
//11=RightControlACW
//4=LeftControlCW
//3=LeftControlACW
bool data;
int Rctrl = 11;
int Lctrl = 3;
int Rpwm = 6;
int Lpwm = 5;
int RpwmVal = 255;
int LpwmVal = 255;
int distance = 100;
pinMode(Rctrl, OUTPUT);
pinMode(Rpwm, OUTPUT);
pinMode(Lctrl, OUTPUT);
pinMode(Lpwm, OUTPUT);
void loop(void) {
data = Serial.find("front");
Serial.print(data);
if (data == true) {
analogWrite(Rpwm, RpwmVal); //pwm
analogWrite(Lpwm, LpwmVal);
digitalWrite(Rctrl, HIGH); //control
digitalWrite(Lctrl, HIGH);
delay(341*0.047506*distance*1.2);
digitalWrite(Rctrl, LOW);
digitalWrite(Lctrl, LOW);
data = false;
else {
See, Im trying to make a arduino car where in if I type front100 in serial monitor, It travels FRONT - 100cm
What I have coded so far :
If I type "front" in the serial monitor, It goes front.
What I can't code :
If I type "front100", the last 3 digits are considered as distance and it travels the distance.
So it was an xy issue ![]()
Have a look at Robin2's serial tutorial for some ideas on how to structure and read data.
edit: why did you mark one post as a solution, but then still say in the next post you don't know how to do it?
its a DELAY. Thanks for help anywaysss ![]()
what about?
adding a space before the decimal makes it easier to recognize
char buf [80];
void
loop (void)
buf [n] = '\0';
char cmd [20];
int val;
sscanf (buf, "%s %d", cmd, &val);
Serial.print (" ");
Serial.print (cmd);
Serial.print (" ");
Serial.println (val);
void
setup (void)
