I'd like to be able to play music files like wavs or mp3's AND use a 64x32 rgb matrix panel in the same project.
additionaly, the audio must be triggerd with minimal lag, so not noticable when triggered by a button press. And, it must be able to play 2 or 3 sounds together at any one time.
has anyone done this? can anyone offer any advice on what hardware and libraries would do this?
more information;
I'm building a batak arcade machine where the aim is to press buttons when they light up, and press as many as possible within a time-frame.
The Arduino DUE or ZERO seems to be the way to go for audio, but they're not supported by the adafruit 'rgb matrix panel' library.
the adafruit wave-shield and music-maker-shield use pin 11, which is also used by the rgb matrix. I dont think this can be resolved.
I've experimented with the adafruit sound-fX-board, but this triggers audio with too much latency. The delay which is said to be 100ms is noticible when triggered by a button press.
I've used a RPI to do this, but would rather use a good old arduino.
