Can I safely power a ESP8266 NodeMCU12E using a mobile charger ?
Yes.. to Vin pin
Powering the board through USB port is OK.
the mobile charger is 5V but NodeMcu 12E is 3.3V . can i use the mobile charger?
Yes, the board has a 3.3V voltage regulator.
thank you
AFAIK most mobile chargers have circuitry that turns them off after a while when current draw is too low.
Don't know if the ~80mA current draw of a NodeMcu is enough to keep the charger going.
Leo..
Wawa:
Leo..
The plug-in types? I've only seen that kind of behavior on USB power-banks.
The plug-in types (wall wart) uses cycle skipping to to almost to zero power consumption. There is still 5V on the output though.
// Per.
