I have 4 LEDs that light up in different brightnesses and durations at the same time. It causes 13 mA at 5V and 7mA at 1V. I want to print the total energy consumed by the LEDs during their operation. How can I do it?
You can use Serial.println(yourvariable); where yourvariable is variable containing your total consumption value
Do you want to use average (fixed) values or actual (measured) values in the calculation of energy consumption ?
How will you, op, be detecting the current of the circuit during operations?
Once the current is detected, then detect the voltage applied. Then multiply the voltage times the current to get the power then Serial.println( power ).
void fReadCurrent( void * parameter )
const TickType_t xFrequency = 1000; //delay for mS
const float mVperAmp = 185.0f;
float ADbits = 4096.0f;
float ref_voltage = 3.3f;
float mA = 0.0f;
float adcValue = 0.0f;
float Voltage = 0.0f;
float Power = 0.0f;
float offSET = 0.0f;
int printCount = 0;
uint64_t TimePastKalman = esp_timer_get_time(); // used by the Kalman filter UpdateProcessNoise, time since last kalman calculation
SimpleKalmanFilter KF_I( 1.0f, 1.0f, .01f );
185mv/A = 5 AMP MODULE
100mv/A = 20 amp module
66mv/A = 30 amp module
String powerInfo = "";
powerInfo.reserve( 150 );
while ( !MQTTclient.connected() )
vTaskDelay( 250 );
TickType_t xLastWakeTime = xTaskGetTickCount();
for (;;)
adc1_get_raw(ADC1_CHANNEL_3); // read once discard reading
adcValue = ( (float)adc1_get_raw(ADC1_CHANNEL_3) );
//log_i( "adcValue I = %f", adcValue );
Voltage = ( (adcValue * ref_voltage) / ADbits ) + offSET; // Gets you mV
mA = Voltage / mVperAmp; // get amps
KF_I.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
mA = KF_I.updateEstimate( mA ); // apply simple Kalman filter
TimePastKalman = esp_timer_get_time(); // time of update complete
printCount++;
if ( printCount == 60 )
xSemaphoreTake( sema_CalculatedVoltage, portMAX_DELAY);
Power = CalculatedVoltage * mA;
//log_i( "Voltage=%f mA=%f Power=%f", CalculatedVoltage, mA, Power );
printCount = 0;
powerInfo.concat( String(CalculatedVoltage, 2) );
xSemaphoreGive( sema_CalculatedVoltage );
powerInfo.concat( ",");
powerInfo.concat( String(mA, 4) );
powerInfo.concat( String(Power, 4) );
xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY );
MQTTclient.publish( topicPower, powerInfo.c_str() );
xSemaphoreGive( sema_MQTT_KeepAlive );
powerInfo = "";
vTaskDelayUntil( &xLastWakeTime, xFrequency );
vTaskDelete( NULL );
} //void fReadCurrent( void * parameter )
void fReadBattery( void * parameter )
const float r1 = 50500.0f; // R1 in ohm, 50K
const float r2 = 10000.0f; // R2 in ohm, 10k potentiometer
float Vbatt = 0.0f;
int printCount = 0;
float vRefScale = (3.3f / 4096.0f) * ((r1 + r2) / r2);
SimpleKalmanFilter KF_ADC_b( 1.0f, 1.0f, .01f );
for (;;)
adc1_get_raw(ADC1_CHANNEL_0); //read and discard
adcValue = float( adc1_get_raw(ADC1_CHANNEL_0) ); //take a raw ADC reading
KF_ADC_b.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
adcValue = KF_ADC_b.updateEstimate( adcValue ); // apply simple Kalman filter
Vbatt = adcValue * vRefScale;
xSemaphoreTake( sema_CalculatedVoltage, portMAX_DELAY );
CalculatedVoltage = Vbatt;
printCount++;
if ( printCount == 3 )
log_i( "Vbatt %f", Vbatt );
printCount = 0;
//log_i( "fReadBattery %d", uxTaskGetStackHighWaterMark( NULL ) );
How do you get leds to light up at 1 volt ?
Is the question about leds relevant to this topic ?
int led = 3;
int ldr = A5;
int ir = A0;
pinMode (led,OUTPUT);
pinMode (ldr,INPUT);
pinMode (ir,INPUT);
Serial.println(analogRead(A5));
int ldrStatus = analogRead (ldr);
if (ldrStatus <=500)
digitalWrite(led, HIGH);
analogWrite(led,51);
if (analogRead(A0)<300) // IR 1 CODE
digitalWrite(led,HIGH);
analogWrite(led,255);
delay(500);// micro second
Here is my code simply. I know it's easy but i am just a beginner so sorry for all these I want to print the calculation of all LEDs. When something appears in front of IR, LED will be 5V when it's not it'll be 1v. Due to unstable bright up and bright down times i can't create the code.
With "analogWrite(led,255/5)" code.
No Serial.begin…?
I want to write a piece of code that collects the 13mA and 7mA currents caused by the leds at different brightnesses at the same time and gives it to the screen.
Will the current only ever be 13mA or 7mA, controlled by the PWM output from the Arduino or can it vary for some other reason and, if so, what ?
Yes only 13 mA and 7mA. I measured the led's current. When it's on high statement it causes 13 mA when is low (i mean 1v) 7mA. Only 2 values. But there are 4 leds. And they're working with IR sensors. So their statements only 13 mA and 7mA too. I want to calculate and print the "total" currents for a certain time. (For example 30 sec)
You are setting the current used by each of the LEDs that you are controlling by writing a voltage to them. Save the value of millis() when you start writing HIGH to an LED and when you write LOW to it subtract the start time from the current value of millis() to get the time spent at 13 mA and add it to the 13 mA total value.
Do the same with the LOW state to get the total LOW state time. When 30 seconds have elapsed, save the time at the current state to the relevant total. Now you have 2 totals
Put the LED pin numbers in an array and you can iterate through the LEDs to add to the totals for all of the LEDs
At the end of 30 seconds do the calculations on the 2 totals to get the total consumption
Why is LOW 1V rather than 0V or close to it ?
You only ever apply 5V to the LED!
'energy consumed' is in Watt-seconds. Watts is Volts times Amps: 5V * 0.013A = 0.065W, 1V * 0.007A = 0.007W. Multiply that by time in seconds to get watt-seconds (or by milliseconds to get Watt-milliseconds.
For a single LED:
float Accumulator = 0.0;
unsigned long TotalPowerConsumed = 0; // Watt-Milliseconds
void SetBrightness(int brightness)
static int lastBrightness = 0;
static unsigned long lastMillis = 0;
if (brightness == lastBrightness)
return; // No change in brightness
unsigned long elapsedMillis = currentMillis - lastMillis;
if (lastBrightness > 0 && elapsedMillis > 0)
float Watts = 0.065 * (lastBrightness/255.0);
float WattMilliseconds = Watts * elapsedMillis;
Accumulator += WattMilliseconds;
int fullWmS = Accumulator;
if (fullWmS > 0)
TotalPowerConsumed += fullWmS;
Accumulator -= fullWmS;
analogWrite(LEDPin, brightness);
lastBrightness = brightness;
lastMillis = currentMillis;
I really appreciate it. Thank you for your lovely support.
Thank you for your time... I will edit my sketch with your support again.
Uh, sorry. I mean (high,51) accidentally typed "low".
