How can i print this value to my Nextion?
#include "EasyNextionLibrary.h"
#include <Wire.h>
#include <Robojax_WCS.h>
#define MODEL 12 //see list above
#define SENSOR_PIN A0 //pin for reading sensor
#define SENSOR_VCC_PIN 8 //pin for powring up the sensor
#define ZERO_CURRENT_LED_PIN 2 //zero current LED pin
#define ZERO_CURRENT_WAIT_TIME 5000 //wait for 5 seconds to allow zero current measurement
#define CORRECTION_VLALUE 164 //mA
#define MEASUREMENT_ITERATION 100
#define VOLTAGE_REFERENCE  5000.0 //5000mv is for 5V
#define BIT_RESOLUTION 10
#define DEBUT_ONCE true
Robojax_WCS sensor(
          MODEL, SENSOR_PIN, SENSOR_VCC_PIN,
          ZERO_CURRENT_WAIT_TIME, ZERO_CURRENT_LED_PIN,
          CORRECTION_VLALUE, MEASUREMENT_ITERATION, VOLTAGE_REFERENCE,
          BIT_RESOLUTION, DEBUT_ONCE
EasyNex myNex(Serial);
int RelayStart = 9;
int Relay1 = 10;
int Relay2 = 11;
int Relay3 = 12;
int Relay4 = 7;
int T = 15000;
int T2 = 1500;
int T3 = 500;
int pin_value = 0;
int progress_value;
myNex.begin(9600);
pinMode(RelayStart,OUTPUT);
pinMode(Relay1,OUTPUT);
pinMode(Relay2,OUTPUT);
pinMode(Relay3,OUTPUT);
pinMode(Relay4,OUTPUT);
digitalWrite(RelayStart,LOW);
digitalWrite(Relay1,LOW);
digitalWrite(Relay2,LOW);
digitalWrite(Relay3,LOW);
digitalWrite(Relay4,LOW);
sensor.start();
   myNex.NextionListen();
   sensor.readCurrent();
   sensor.printCurrent();
void trigger0(){
  digitalWrite(Relay1, !digitalRead(Relay1));
void trigger1(){
void trigger2(){
digitalWrite(RelayStart,!digitalRead(RelayStart));
Hi all,
Iam new to arduino and i have a question. When "sensor.printCurrent" is activated this happens in the library:
void Robojax_WCS::printCurrent()
   Serial.print("Current:");
   Serial.print(getCurrent(),2);
   Serial.println("A");
}//printCurrent()
I want the part " Serial.print(getCurrent(),2);" to print on my Nextion. To print variables on the Nextion i use an library which uses the code "myNex.writeNum("x0.val", Anything);" to print values to the Nextion. If i can convert the getCurrent to an int or something else i think i can print it. Does someone have an idea what to do? Thanks in Advance.
The getCurrent code:
float Robojax_WCS::getCurrent()
 //robojax.com WCS Current Measurement for Arduino
    float averageSensorValue =0;
    int sensorValue ;
    float voltage, current;
    for(int i=0; i< _iteration; i++)
      sensorValue = analogRead(_vin);
      //Serial.print("S:");Serial.println(sensorValue);
      delay(2);
        voltage = (sensorValue) * (_voltageReference /  (pow(2,_bitResolution)-1)) -( _quiescent_Output_voltage[_model] * _voltageReference) + _correctionValue ;
       //Serial.print("V:");Serial.println(voltage);
        current  = voltage / _sensitivity[_model]  ;
          averageSensorValue += current;
    averageSensorValue /=_iteration;
    if(_zeroCurrentSet)
     averageSensorValue -=_zeroCurrentValue;//subtract the zero current value
    return   averageSensorValue;
}//getCurrent()
Try... int getCurrent(),
Thanks for your response, int getCurrent(); does not cause any errors but when i try to send it to Nextion it doesn`t work.
int getCurrent();
myNex.writeNum("x0.val", getCurrent);
Don't redefine the function. Only tell the compiler to add code to convert from float to int in the print/write situation.
"Doesn't work " tells nothing.
Ok so i added the int getCurrent(); how should i continue?
int tempInt = temperature*10;      // Convert the float to int. Multiply it x10
myNex.writeNum("x1.val", tempInt); // Write it to x1 Xfloat component on Nextion
This is an example of a piece of code that does work.
I want to send the getCurrent to change "x0.val"
@PerryBebbington sounds like one for you.
Hi Bob,
Thanks but @shieftech is using @Seithan's Easy Nextion Library, about which I know nothing. Maybe @Seithan can help.
Moved to the display section as this is about a display.
It looks like You have changed the original code You posted. Don't do that! Post new or changed code in Your following posts. Now I don't find the print/write line of code.
Post the original code down here.
I haven`t changed the code. The piece of code i provided in my last answer is just an example code from the owner of the library. The original code is still the same as the one I posted the first time.
Here i have the piece of code which should send the data to my Nextion:
  int current = getCurrent;
   myNex.writeNum("x0.val", current);
`But when I try to upload this I get the error message: cannot convert 'Robojax_WCS::getCurrent' from type 'float (Robojax_WCS::)()' to type 'int'.
Okey. I had a slow day...
In my first reply what I suggested should look like this:
Your later attempt, redfineing the float function getCurrent to be an int.... Drop that!
