How can I programme an Arduino to perform an action once and once only?
How can I programme an Arduino so that when a rain sensor indicates that it is raining, it runs a stepper motor once and once only, and then effectively shuts down until it is manually reset?
Context: I have built a prototype window auto-close unit that combines a rain sensor, an Elegoo Uno R3, a Pololu High-Power Stepper Motor Driver 36v4 and a 24v/4.2A stepper motor into a single unit - all powered by a 24v/5A mains adapter (240v UK). The unit is completely portable and self-contained - there is no data or power connection to a laptop, PC, WiFi router or similar device.
It performs a very simple, one-off operation. Whenever it starts to rain, the motor is activated, turning a pulley that reels in a wire cable that closes a top-hung Velux window from near-horizontal (open) to 45 degrees (closed). That’s it. The window stays shut until the householder wakes up, checks that it has stopped raining, and then manually re-sets the unit as needed.
I have combined a generic stepper motor sketch from Pololu with a rain sensor sketch - see below. The problem is that as currently programmed, whenever it starts to rain the Arduino will constantly re-check the sensor reading and then constantly re-start the motor. This would be great for a car windscreen wiper, but in my case it would end up breaking the motor, the cable, my electronics and/or the window. So I need to break that loop. What would people suggest?
Thanks!
#include <SPI.h>
#include <HighPowerStepperDriver.h>
const uint8_t CSPin = 4;
// This period is the length of the delay between steps, which controls the
// stepper motor's speed.
const uint16_t StepPeriodUs = 300;
HighPowerStepperDriver sd;
int rainsense = 0; // analog sensor input pin 0
int activatemotor = 11; // digital output pin 11 - activate 5v supply from Arduino to motor controller
int countval = 0; // counter value starting from 0 and goes up by 1 every second
  //Rain sensor setup
  pinMode(activatemotor, OUTPUT);
  pinMode(rainsense, INPUT);
  //Stepper motor setup
    SPI.begin();
    sd.setChipSelectPin(CSPin);
    // Give the driver some time to power up.
    delay(1);
    // Reset the driver to its default settings and clear latched status
    // conditions.
    sd.resetSettings();
    sd.clearStatus();
    // Set the current limit. You should change the number here to an appropriate
    // value for your particular system.
    sd.setCurrentMilliamps36v4(4200);
    // Set the number of microsteps that correspond to one full step.
    sd.setStepMode(HPSDStepMode::MicroStep32);
  int rainSenseReading = analogRead(rainsense);
  Serial.println(rainSenseReading); // serial monitoring message
  delay(250);
  // The rain sensor produces a value from 0 (wet) to 697 (dry), using the 3.3v feed from the Arduino.
  // In the following line, you can set the amount of rain needed for the motor to be activated.
  if (rainSenseReading <= 400) {
    // If it is raining, then enable the motor outputs.
    sd.enableDriver();
    // Step in the specified direction and for the specified number of times.
    sd.setDirection(1);
    for (unsigned int x = 0; x < 32000; x++)
      sd.step();
      delayMicroseconds(StepPeriodUs);
    sd.disableDriver();
notice the addition of bool DoTheThing =. true;?
#include <SPI.h>
bool DoTheThing = true; //see loop()
  //Rain sensor setup
    SPI.begin();
    delay(1);
    // conditions.
    sd.resetSettings();
    sd.clearStatus();
if( DoTheThing )
  delay(250);
    sd.enableDriver();
    sd.setDirection(1);
      sd.step();
    sd.disableDriver();
DoTheThing=false;
Now loop() will only run your code once.
Wow - thanks for the fast response Idahowalker. Really appreciate that.
Unfortunately when I tried to upload, I got the following error message:
Arduino: 1.8.13 (Windows 10), Board: “Arduino Uno”
4:18: error: expected primary-expression before ‘.’ token
The dot is a typo - remove it.
wildbill:
Thanks, fixed. +1
That's done the trick - many thanks!
I'm not sure if waking up to damp carpets is a big worry in Idaho, but you might just have helped this English family to sleep more easily on those rare hot summer nights... :sleeping:
Instead of a reset, add a button to the project that when a press is detected changes the DoTheThing back to true.
Then you could add in a LED that indicates if the program is running or stalled.
You are welcome, +1.
The traditional way to "do something once" is to put it in setup() instead of loop().
