How can I push my SD data to cloud like Google sheet?
Hi there,
Sorry, I'm a total beginner. I was wondering if anyone can help me with this project. I have just learned how to record data from my sensors into an SD card and this is the code.
  SD card datalogger
 This example shows how to log data from three analog sensors
 to an SD card using the SD library.
 The circuit:
 * SD card attached to SPI bus as follows:
 ** UNO:  MOSI - pin 11, MISO - pin 12, CLK - pin 13, CS - pin 4 (CS pin can be changed)
  and pin #10 (SS) must be an output
 ** Mega:  MOSI - pin 51, MISO - pin 50, CLK - pin 52, CS - pin 4 (CS pin can be changed)
  and pin #52 (SS) must be an output
 ** Leonardo: Connect to hardware SPI via the ICSP header
 		Pin 4 used here for consistency with other Arduino examples
 created  24 Nov 2010
 modified 9 Apr 2012 by Tom Igoe
 This example code is in the public domain.
#include <Wire.h>
#include <dht.h>
#include <SPI.h>
#include <SD.h>
#include <DS3231.h>
dht DHT;
DS3231  rtc(SDA, SCL); //  associate rtc with DS3231 library
String data, date, time;
#define Dht A2//Dht
int TemPin= A0;  //tmp
int LDR= A1; //Ldr
long check, light, temp, humid;
// On the Ethernet Shield, CS is pin 4. Note that even if it's not
// used as the CS pin, the hardware CS pin (10 on most Arduino boards,
// 53 on the Mega) must be left as an output or the SD library
// functions will not work.
const int chipSelect = 4;
File dataFile;
  Wire.begin();
  pinMode(LDR, INPUT); // LDR INPUT
  rtc.begin();
  rtc.setDOW(SUNDAY);  // set weekday
  rtc.setTime(10, 43, 40); // set the time to hh mm ss
  rtc.setDate(27, 2, 2022); // set the date to dd mm yyyy
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("Initializing SD card...");
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(SS, OUTPUT);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    while (1) ;
  Serial.println("card initialized.");
  // Open up the file we're going to log to!
  dataFile = SD.open("datalog.txt", FILE_WRITE);
  if (! dataFile) {
    Serial.println("error opening datalog.txt");
    // Wait forever since we cant write data
    while (1) ;
  // make a string for assembling the data to log:
  String dataString = "";
  String datatwo ="";
  // read three sensors and append to the string:
  for (int analogPin = 0; analogPin < 4; analogPin++) {
    DHT.read11(Dht);
    int Humid = (DHT.humidity);
    int Light = analogRead(LDR);
        //Tempreture Setup//
  int Tempreading = analogRead(TemPin);
              // Convert the reading into voltage:
  float voltage = Tempreading * (5000 / 1024.0); //temp
  // Convert the voltage into the temperature in degree Celsius:
   int tempo = voltage / 10; //temp
    //  time = rtc.getTimeStr();   String(time)+ "," +
       dataString =String(tempo)+"\xC2\xB0"+","+ String(Light)+","+String(Humid)+"%";
    if (analogPin < 4) {
      dataString += ",";
  dataFile.println(dataString);
  // print to the serial port too:
  Serial.println(dataString);
  // The following line will 'save' the file to the SD card after every
  // line of data - this will use more power and slow down how much data
  // you can read but it's safer!
  // If you want to speed up the system, remove the call to flush() and it
  // will save the file only every 512 bytes - every time a sector on the
  // SD card is filled with data.
  dataFile.flush();
  // Take 1 measurement every 500 milliseconds
Now I succeeded in saving records in my SD. However, my next step was to save the data stored with a comma between them to spreadsheet. The comma between reading meant to set each reading on its own cell.
I was trying out the Pushingbox website to record live sensors data in a spreadsheet and I followed few instructions on youtube, but I kept failing.
Now I was wondering if there is a way to just send all the data I was recording on my SD to a spreadsheet?
