how can I put preceding '0' in a binary number
Greetings,
If I want to print a number 0~255 in binary. for example, I could use Serial.print(100,BIN). And the result is "1100100".
My question is how can I put preceding '0's in front, make it always 8 digits as 01100100? 'print (100,BIN,8)' or the '%08d' way does not work.
thanks
Research "sprintf" http://www.cplusplus.com/reference/cstdio/sprintf/ http://www.cplusplus.com/reference/cstdio/printf/
LarryD: Research "sprintf" http://www.cplusplus.com/reference/cstdio/sprintf/ http://www.cplusplus.com/reference/cstdio/printf/
I did, but I cannot find a specifier for binary number... If I am using DEC or HEX, there would be no problem.
Right.
You could write a function that prints 1s and 0s when you examine each bit individually as you shift a 1 from one bit to the next.
LarryD: Right.
I see, probably there is no easy way for that. I can use bitRead to read all 8 digits and print them one by one...
byte b = yourData
for (byte i = 7; i >= 0; i-- )
      Serial.print((b >> i) & 0X01);//shift and select first bit
Also:
byte myByte = 0b01011111;
  for(int x = 7; x >= 0; x--)
    Serial.print(bitRead(myByte,x));
  while(1);
