how can i query the status of the built-in led in blynk of my esp-wroom32 board my digital pin is 5
can you also convert this digital pin to a virtual pin?
Does blynk use the Arduino IDE?
bool status = digitalRead(5);
here is the code ( its for an automatic planter )
but on Blynk i want to see if the led on my ESP32 wroom is on
the led is on digitalpin 5
// Fill-in information from your Blynk Template here
#define BLYNK_TEMPLATE_ID "***************"
#define BLYNK_TEMPLATE_NAME "***************"
#define BLYNK_FIRMWARE_VERSION "0.1.0"
#define BLYNK_PRINT Serial
//#define BLYNK_DEBUG
//#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_WROVER_BOARD
#include "BlynkEdgent.h"
#include <driver/adc.h>
//Global variables for unit conversion
#define hoursToSeconds 3600LL //conversion factor from hours to seconds --> suffix LL for definition as 64bit constant
#define secondsToMikroseconds 1000000LL //conversion factor from seconds to mikroseconds --> suffix LL for definition as 64bit constant
//PIN Configuration
//Conflict with analog ADC2 Pins and Wifi --> they stop working forever after wifi is startet --> only use ADC1 Pins (32,33,34,35,36,39) for analogread
const byte buttonPin = 0; //If changed, the pin also has to be changed in the Sleep function
const byte batteryLevelPin = 32; //voltage divider with 1MOhm and 30KOhm Resistor used to reduce maximum volatge at this pin (3.4V to 3.33V) --> at minimum operating voltage of 2.55V(???) readings at this pin would be 2,47V
const byte pumpPowerPin = 23;
const byte moistureSensorPowerPin = 19;
const byte moistureSensorSignalPin = 33;
const byte waterLevelGroundPin = 35; //lowest cable in tank, connect 100kohm Resistor to Ground parallel as pulldown resitor
const byte waterLevelPin[] = {13, 14, 27, 26, 25}; //Pins for Sensores in Tank --> Order: 100%, 75%, 50%, 25%, 10%
//Config values --> can be changed in the Blynk app
//RTC Memory values --> these are preserved during deepsleep but lost when reseting or powering off the esp32
RTC_DATA_ATTR int bootCount = 0;
RTC_DATA_ATTR int sleepDuration = 28; //sleep time in minutes
RTC_DATA_ATTR int soilMoistureCritical = 25; //critical soil moisture in % that initiates watering process
RTC_DATA_ATTR int waterAmount = 20;
RTC_DATA_ATTR int pumpPowerMin = 150;
RTC_DATA_ATTR int pumpPowerMax = 230;
RTC_DATA_ATTR int waterFlowCalibration = 250;
RTC_DATA_ATTR int soilMoistureCalibrationAir = 3180;
RTC_DATA_ATTR int soilMoistureCalibrationWater = 1320;
RTC_DATA_ATTR int waterLevelSensorThreshold = 400;
//Flag values (boolean) that are received from the Blynk app --> get reset after reboot or deepsleep
int pumpPowerMinCalibrationFlag = 0;
int pumpPowerMaxCalibrationFlag = 0;
int waterFlowCalibrationFlag = 0;
int soilMoistureCalibrationAirFlag = 0;
int soilMoistureCalibrationWaterFlag = 0;
int waterLevelSensorRawReadingsFlag = 0;
//Global variables for state machine operation
byte downloadBlynkState = 0;
byte uploadBlynkState = 0;
byte batteryLevelMeasureState = 0;
byte waterLevelMeasureState = 0;
byte soilMoistureMeasureState = 0;
byte pumpOperationState = 0;
byte routineState = 0;
//Global variables (Blynk related)
int blynkSyncCounter = 0;
int blynkSyncNumber = 15; //number of values that have to be downloaded from Blynk server during synchronisation
boolean blynkSyncRequired = false; //flag if sync with Blynk server is required
boolean BlynkInitialized = false;
//Other global variables
esp_sleep_wakeup_cause_t deepsleepWakeupReason;
const int sensorMeasureWaitingTime = 200; //200ms between measurements --> same for all measurement functions
int batteryLevelReading[10];
int batteryLevelAverage = 0;
float batteryLevelVoltage = 0;
int batteryLevelPercentage = 0;
int waterLevelSensorReading[5];
int waterLevelPercentage = 0;
const int waterLevelAssociated[] = {100, 75, 50, 25, 10, 0}; //water levels in % associated with each pin
int soilMoistureReading[10];
int soilMoistureAverage = 0;
int soilMoistureCalibrated = 0;
int soilMoisturePercentage = 0;
int pumpActivityFlag = 0;
void setup(){
delay(500); //delay here is required to wake up reliably
pinMode(LED_BUILTIN,OUTPUT);
pinMode(buttonPin, INPUT);
pinMode(batteryLevelPin, INPUT);
pinMode(pumpPowerPin, OUTPUT);
pinMode(moistureSensorSignalPin, INPUT);
pinMode(moistureSensorPowerPin, OUTPUT);
pinMode(waterLevelGroundPin, INPUT); //cathode --> only here no corrosion
for (int i = 0; i < 5; i++) {
pinMode(waterLevelPin[i], INPUT); //corrosion on these anodic pins
pinMode(LED_BUILTIN, OUTPUT);
//digitalWrite(LED_BUILTIN, LOW); // turn the LED ON (strangely Builddin LED is active LOW) --> turns off when entering deepsleep
delay(100); //wait for serial monitor to open
bootCount++;
BLYNK_LOG("Bootcount: %i", bootCount);
timer.setTimeout(120000L, DeepSleep); // Setup DeepSleep function to be called after 120000 second --> go to deep sleep if anything takes to long
routineState = 1;
void routine(){
switch(routineState){
case 1: //download new config values from Blynk if sync is required
downloadBlynkState = 1;
routineState++;
case 2: //start measuring processes
if(downloadBlynkState == 100){
batteryLevelMeasureState = 1;
waterLevelMeasureState = 1;
soilMoistureMeasureState = 1;
routineState++;
case 3:
if(batteryLevelMeasureState == 100 && waterLevelMeasureState == 100 && soilMoistureMeasureState == 100){
serialPrintValues(); //print measurement values to serial monitor
pumpOperationState = 1; //start the pump
routineState++;
case 4:
if(pumpOperationState == 100){
uploadBlynkState = 1; //upload new values
routineState++;
case 5:
if(uploadBlynkState == 100){
DeepSleep();
void downloadBlynk(){
switch(downloadBlynkState){
case 1:
// esp_sleep_wakeup_cause_t deepsleepWakeupReason = esp_sleep_get_wakeup_cause(); //get wakeup reason
if(deepsleepWakeupReason == ESP_SLEEP_WAKEUP_EXT0 || bootCount == 1){ //if this is the first boot or if button was used to wake up manually
BLYNK_LOG("This is the first boot of the microcontroller or it was manually woken up from standby mode by button press");
blynkSyncRequired = true;
BlynkEdgent.begin();
BlynkInitialized = true;
downloadBlynkState++;
else{
BLYNK_LOG("The microcontroller was regularly woken up from standby mode by the timer - synchronisation with Blynk server is not necassary");
downloadBlynkState = 100; //mark task as finished
case 2:
if(blynkSyncCounter == blynkSyncNumber){ //if all values have been updated
BLYNK_LOG("Synchronisation finished!");
blynkSyncRequired = false; //reset flag
blynkSyncCounter = 0; //reset counter
Blynk.disconnect();
WiFi.disconnect();
else{
BLYNK_LOG("Waiting for synchronisation to complete...");
void uploadBlynk(){
static unsigned long previousUploadCheckTime = 0;
switch(uploadBlynkState){
case 1:
BLYNK_LOG("Uploading new values to Blynk...");
uploadBlynkState++;
case 2:
if (millis() - previousUploadCheckTime >= 3000){ //check every 3 seconds if boot count has been uploaded yet
previousUploadCheckTime = millis();
Blynk.syncVirtual(V104); //needed to trigger BLYNK_WRITE(V104)
BLYNK_CONNECTED() { //gets called as soon as connection to Blynk server is established
if(blynkSyncRequired == true){
BLYNK_LOG("Synchronisation with Blynk server started");
Blynk.syncVirtual(V105, V106, V107, V0, V1, V2, V10, V3, V4, V5, V6, V7, V8, V9, V11); //get latest config values from Blynk server
else{
BLYNK_LOG("Upload of new values to Blynk server started");
Blynk.virtualWrite(V102, batteryLevelPercentage);
Blynk.virtualWrite(V101, waterLevelPercentage);
if(waterLevelSensorRawReadingsFlag == 1){
Blynk.virtualWrite(V12, waterLevelSensorReading[0]); //upload raw reading on 100% pin
Blynk.virtualWrite(V13, waterLevelSensorReading[1]); //upload raw reading on 75% pin
Blynk.virtualWrite(V14, waterLevelSensorReading[2]); //upload raw reading on 50% pin
Blynk.virtualWrite(V15, waterLevelSensorReading[3]); //upload raw reading on 25% pin
Blynk.virtualWrite(V16, waterLevelSensorReading[4]); //upload raw reading on 10% pin
Blynk.virtualWrite(V11, 0); //upload zero to reset flag on server if it was set
Blynk.virtualWrite(V100, soilMoisturePercentage);
if(soilMoistureCalibrationAirFlag == 1){
Blynk.virtualWrite(V5, soilMoistureCalibrationAir);
Blynk.virtualWrite(V7, 0); //upload zero to reset flag on server if it was set
if(soilMoistureCalibrationWaterFlag == 1){
Blynk.virtualWrite(V6, soilMoistureCalibrationWater);
Blynk.virtualWrite(V8, 0); //upload zero to reset flag on server if it was set
Blynk.virtualWrite(V103, pumpActivityFlag);
if(pumpPowerMinCalibrationFlag == 1 || pumpPowerMaxCalibrationFlag == 1 || waterFlowCalibrationFlag == 1){ //upload zero to reset flags on server if any of them was set
Blynk.virtualWrite(V4, 0);
Blynk.virtualWrite(V2, 0);
Blynk.virtualWrite(V10, 0);
Blynk.virtualWrite(V104, bootCount);
BLYNK_WRITE(V104){ //gets called by Blynk.syncVirtual function
int bootCountServer = param.asInt(); // Get value as int
if(bootCount == bootCountServer){ //if boot count on device and server are matching --> upload has finished
BLYNK_LOG("Upload of new values to Blynk server confirmed");
uploadBlynkState = 100; //mark upload task as finsihed
BLYNK_WRITE(V105){ //gets called by Blynk.syncVirtual function
sleepDuration = param.asInt(); // Get value as int
BLYNK_LOG("New value for sleep duration received: %i", sleepDuration);
blynkSyncCounter++;
BLYNK_WRITE(V106){ //gets called by Blynk.syncVirtual function
soilMoistureCritical = param.asInt(); // Get value as int
BLYNK_LOG("New value for critical soil moisture received: %i", soilMoistureCritical);
blynkSyncCounter++;
BLYNK_WRITE(V107){ //gets called by Blynk.syncVirtual function
waterAmount = param.asInt(); // Get value as int
BLYNK_LOG("New value for water amount received: %i", waterAmount);
blynkSyncCounter++;
BLYNK_WRITE(V0){ //gets called by Blynk.syncVirtual function
pumpPowerMin = param.asInt(); // Get value as int
BLYNK_LOG("New value for minimal pump power received: %i", pumpPowerMin);
blynkSyncCounter++;
BLYNK_WRITE(V1){ //gets called by Blynk.syncVirtual function
pumpPowerMax = param.asInt(); // Get value as int
BLYNK_LOG("New value for maximum pump power received: %i", pumpPowerMax);
blynkSyncCounter++;
BLYNK_WRITE(V2){ //gets called by Blynk.syncVirtual function
pumpPowerMinCalibrationFlag = param.asInt(); // Get value as int
BLYNK_LOG("New flag for minimum pump power calibration received: %i", pumpPowerMinCalibrationFlag);
blynkSyncCounter++;
BLYNK_WRITE(V10){ //gets called by Blynk.syncVirtual function
pumpPowerMaxCalibrationFlag = param.asInt(); // Get value as int
BLYNK_LOG("New flag for maximum pump power calibration received: %i", pumpPowerMaxCalibrationFlag);
blynkSyncCounter++;
BLYNK_WRITE(V3){ //gets called by Blynk.syncVirtual function
waterFlowCalibration= param.asInt(); // Get value as int
BLYNK_LOG("New value for water flow calibration received: %i", waterFlowCalibration);
blynkSyncCounter++;
BLYNK_WRITE(V4){ //gets called by Blynk.syncVirtual function
waterFlowCalibrationFlag= param.asInt(); // Get value as int
BLYNK_LOG("New flag for water flow calibration received: %i", waterFlowCalibrationFlag);
blynkSyncCounter++;
BLYNK_WRITE(V5){ //gets called by Blynk.syncVirtual function
soilMoistureCalibrationAir= param.asInt(); // Get value as int
BLYNK_LOG("New value for soil moisture calibration in air received: %i", soilMoistureCalibrationAir);
blynkSyncCounter++;
BLYNK_WRITE(V6){ //gets called by Blynk.syncVirtual function
soilMoistureCalibrationWater= param.asInt(); // Get value as int
BLYNK_LOG("New value for soil moisture calibration in water received: %i", soilMoistureCalibrationWater);
blynkSyncCounter++;
BLYNK_WRITE(V7){ //gets called by Blynk.syncVirtual function
soilMoistureCalibrationAirFlag= param.asInt(); // Get value as int
BLYNK_LOG("New flag for soil moisture calibration in air received: %i", soilMoistureCalibrationAirFlag);
blynkSyncCounter++;
BLYNK_WRITE(V8){ //gets called by Blynk.syncVirtual function
soilMoistureCalibrationWaterFlag= param.asInt(); // Get value as int
BLYNK_LOG("New flag for soil moisture calibration in water received: %i", soilMoistureCalibrationWaterFlag);
blynkSyncCounter++;
BLYNK_WRITE(V9){ //gets called by Blynk.syncVirtual function
waterLevelSensorThreshold= param.asInt(); // Get value as int
BLYNK_LOG("New value for water level sensor threshold received: %i", waterLevelSensorThreshold);
blynkSyncCounter++;
BLYNK_WRITE(V11){ //gets called by Blynk.syncVirtual function
waterLevelSensorRawReadingsFlag= param.asInt(); // Get value as int
BLYNK_LOG("New flag for raw water level sensor readings received: %i", waterLevelSensorRawReadingsFlag);
blynkSyncCounter++;
void batteryLevelMeasure() {
static int batteryReadingCounter = 0;
static unsigned long previousBatteryLevelMeasureTime = 0;
switch(batteryLevelMeasureState){
case 1: //do this on first run of this task -> reset values
batteryLevelMeasureState++;
case 2:
if(batteryReadingCounter < 10 && millis() - previousBatteryLevelMeasureTime >= sensorMeasureWaitingTime){ //do 10 measurement repetitions every few milliseconds
previousBatteryLevelMeasureTime = millis(); //reset measure timer
batteryLevelReading[batteryReadingCounter] = analogRead(batteryLevelPin);
batteryLevelAverage += batteryLevelReading[batteryReadingCounter]; //add current sensor reading to average
batteryReadingCounter++;
if(batteryReadingCounter == 10){
case 3: //after all measurement repetitions have been performed
batteryLevelAverage = batteryLevelAverage / 10;
batteryLevelVoltage = batteryLevelAverage / 4096.0 * 4.62; //conversion of raw reading to voltage -> multiply with 3.3 by default because of 3.3V basic voltage of the ESP32 --> here its multiplyed by 1.33 (=4.39) because of the voltage divider in the circuit and corrected with an additional correction factor => 4.62
batteryLevelPercentage = 2808.3808 * pow(batteryLevelVoltage, 4) - 43560.9157 * pow(batteryLevelVoltage, 3) + 252848.5888 * pow(batteryLevelVoltage, 2) - 650767.4615 * batteryLevelVoltage + 626532.9; //conversion from voltage to percentage by using a fitting function for the charge-voltage-curve of an LiPo battery
if (batteryLevelVoltage > 4.2){
batteryLevelPercentage = 100;
if (batteryLevelVoltage < 3.5){
batteryLevelMeasureState = 100; //mark task as finsihed
void waterLevelMeasure() {
static int waterLevelPinIndex = 0;
static unsigned long previousWaterLevelMeasureTime = 0;
switch(waterLevelMeasureState){
for (int n = 0; n < 5; n++) {
waterLevelSensorReading[n] = 0;
waterLevelMeasureState++;
case 2:
if (waterLevelPinIndex < 5){ //do this up to 5 times (once for each pin) --> Start measuring from top pins and ends at bottom pins, so pins under water are tested less frequently --> less corrosion on these pins
pinMode(waterLevelPin[waterLevelPinIndex], OUTPUT); //set specific water level pin under test to output
digitalWrite(waterLevelPin[waterLevelPinIndex], HIGH); //activate power on specific water level pin under test
if (millis() - previousWaterLevelMeasureTime >= sensorMeasureWaitingTime) { //wait for the voltage on the pin to rise
previousWaterLevelMeasureTime = millis(); //reset timer
waterLevelSensorReading[waterLevelPinIndex] = analogRead(waterLevelGroundPin); //read voltage on ground pin -> if ground and the specific pin under test are connected by water in the tank -> high value
digitalWrite(waterLevelPin[waterLevelPinIndex], LOW); //cut off power to pin
pinMode(waterLevelPin[waterLevelPinIndex], INPUT); //set pin to input
if(waterLevelSensorReading[waterLevelPinIndex] >= waterLevelSensorThreshold && waterLevelPercentage == 0){ // if the specific pin under test and ground pin ARE connectet AND current water level hasent been found yet
waterLevelPercentage = waterLevelAssociated[waterLevelPinIndex]; //this is the current Water level
if(waterLevelSensorRawReadingsFlag == 0 && waterLevelPercentage != 0){ //if raw values should NOT be printed AND current water level has been found
waterLevelMeasureState = 100; //mark task as finished
waterLevelPinIndex++; //check next pin
else{
void soilMoistureMeasure() {
static int soilMoistureReadingCounter = 0;
static unsigned long previousSoilMoistureSensorMeasureTime = 0;
switch(soilMoistureMeasureState){
digitalWrite(moistureSensorPowerPin, HIGH); //power up the sensor
previousSoilMoistureSensorMeasureTime = millis(); //reset measurement timer -> to wait a short time before measuring for the voltage on the sensor to rise
soilMoistureMeasureState++;
case 2:
if(soilMoistureReadingCounter < 10 && millis() - previousSoilMoistureSensorMeasureTime >= sensorMeasureWaitingTime){ //do 10 measurement repetitions every few milliseconds
previousSoilMoistureSensorMeasureTime = millis(); //reset measure timer
soilMoistureReading[soilMoistureReadingCounter] = analogRead(moistureSensorSignalPin);
soilMoistureAverage += soilMoistureReading[soilMoistureReadingCounter]; //add current sensor reading to average
soilMoistureReadingCounter++;
if(soilMoistureReadingCounter == 10){
digitalWrite(moistureSensorPowerPin, LOW); //cut off power to the sensor
soilMoistureAverage = soilMoistureAverage / 10; //divide the sum of the readings by the number of measurement repetitions
soilMoistureCalibrationAir = soilMoistureAverage;
soilMoistureCalibrationWater = soilMoistureAverage;
soilMoistureCalibrated = map(soilMoistureAverage, soilMoistureCalibrationWater, soilMoistureCalibrationAir, 1320, 3173); //calibrate new value with map function
soilMoisturePercentage = (178147020.5 - 52879.727 * soilMoistureCalibrated) / (1 - 428.814 * soilMoistureCalibrated + 0.9414 * pow(soilMoistureCalibrated, 2)); //Fitting function to calculate %-value
if (soilMoisturePercentage > 100) {
soilMoisturePercentage = 100;
if (soilMoisturePercentage < 0) {
soilMoistureMeasureState = 100; //mark task as finsihed
void serialPrintValues() {
for (int n = 0; n < 10; n++) {
BLYNK_LOG("Raw battery level reading %i: %i", n + 1, batteryLevelReading[n]);
BLYNK_LOG("Average battery level reading: %i", batteryLevelAverage);
BLYNK_LOG("Battery level voltage: %f V", batteryLevelVoltage);
BLYNK_LOG("Battery level percentage: %i %%", batteryLevelPercentage);
BLYNK_LOG("Raw reading for pin on water level %i: %i", waterLevelAssociated[n], waterLevelSensorReading[n]);
BLYNK_LOG("Water level percentage: %i %%", waterLevelPercentage);
BLYNK_LOG("Raw soil moisture reading %i: %i", n + 1, soilMoistureReading[n]);
BLYNK_LOG("Average soil moisture reading: %i", soilMoistureAverage);
BLYNK_LOG("Calibrated soil moisture reading: %i", soilMoistureCalibrated);
BLYNK_LOG("Soil moisture percentage: %i", soilMoisturePercentage);
void pumpOperation(){
static const int pumpPwmFrequency = 490; //frequency of the PWM signal in Hertz -> maximum resolution depends on frequency (higher frequency means lower possible resolution -> max freq [in Hz] = 80000000/(2^resolution) ) -> frequency effects noise of the pump
static const int pumpPwmChannel = 0; //choose a PWM channel -> There are 16 channels from 0 to 15
static const int pumpPwmResolution = 8; //resolution for the duty cyle of the PWM signal in bit, higher resolution means finer adjustment -> duty cycle range from 0 to (2^resolution) - 1) -> e.g. 8 bit => duty cycle between 0 and 255
static float batteryVoltageCompensationValue; //compensation value to always power the pump with 3.5V (lowest possible battery voltage), independet of the actual battery voltage
static int pumpOperationDuration = 10000; // set default pump duration to 10000 milliseconds (10 seconds)
static unsigned long pumpOperationTime; //starting time of the pump operation
static int pumpPwmDutyCycle; //duty cycle of the PWM signal -> controls power of the pump
static int pumpPwmDutyCycleMin; //starting duty cycle
static int pumpPwmDutyCycleMax; //ending duty cycle
static int dutyCycleRestTime; //time after that duty cycle is increased by 1
static unsigned long previousDutyCycleIncreaseTime; //last time the duty cycle was increased
switch(pumpOperationState){
case 1:
if(soilMoisturePercentage <= soilMoistureCritical || pumpPowerMinCalibrationFlag == 1 || pumpPowerMaxCalibrationFlag == 1 || waterFlowCalibrationFlag == 1){ //check if pump needs to be started
if(waterLevelPercentage < 10){ //if the water level is less then 10%
BLYNK_LOG("Water level is too low - minimum water level for pump operation is 10%");
pumpOperationState = 100; //mark task as finished
if(batteryLevelPercentage < 10){ //if the battery level is less then 10%
BLYNK_LOG("Battery level is too low - minimum battery level for pump operation is 10%");
if(waterLevelPercentage >= 10 && batteryLevelPercentage >= 10){
pumpOperationState++;
else{
BLYNK_LOG("No need to start water pump");
case 2:
ledcSetup(pumpPwmChannel, pumpPwmFrequency, pumpPwmResolution); // configure the PWM signal functionalitites for controling the pump
ledcAttachPin(pumpPowerPin, pumpPwmChannel); // attach a channel to one Pin for generating the PWM signal for controling the pump
batteryVoltageCompensationValue = -0.238 * batteryLevelVoltage + 1.833; //calculate compensation value to always power the pump with 3.5V (lowest possible battery voltage), independet of the actual battery voltage
if(pumpPowerMinCalibrationFlag == 1){ //dont change pump PWM while calibrating pump (min and max are almost the same -> +1 to avoid dividing by zero later)
pumpPwmDutyCycleMin = pumpPowerMin * batteryVoltageCompensationValue;
pumpPwmDutyCycleMax = pumpPowerMin * batteryVoltageCompensationValue + 1;
else if(pumpPowerMaxCalibrationFlag == 1){ //dont change pump PWM while calibrating pump (min and max are almost the same -> +1 to avoid dividing by zero later)
pumpPwmDutyCycleMin = pumpPowerMax * batteryVoltageCompensationValue;
pumpPwmDutyCycleMax = pumpPowerMax * batteryVoltageCompensationValue + 1;
else{ //increase pump PWM during operation
pumpPwmDutyCycleMax = pumpPowerMax * batteryVoltageCompensationValue;
if (waterFlowCalibrationFlag == 1){
pumpOperationDuration = 60000; // set pump duration to 60000 milliseconds (60 seconds)
else{
pumpOperationDuration = 60000 * waterAmount / waterFlowCalibration; //calculate how long the pump has to operate to pump the desired amount of water --> mulitply by 60000 to get result in milliseconds
BLYNK_LOG("Amount of water to pump: %i mL", waterAmount);
dutyCycleRestTime = pumpOperationDuration / (pumpPwmDutyCycleMax - pumpPwmDutyCycleMin); //calculate after how many milliseconds the duty cycle has to be increased in steps of 1, so that it reaches the maximum duty cycle at the end of the pump duration
BLYNK_LOG("Pumping duration: %i milliseconds", pumpOperationDuration);
BLYNK_LOG("Starting pump PWM duty cycle at: %i", pumpPwmDutyCycleMin);
BLYNK_LOG("Ending pump PWM duty cycle at: %i", pumpPwmDutyCycleMax);
BLYNK_LOG("Increasing PWM duty cycle by 1 every: %i milliseconds", dutyCycleRestTime);
pumpPwmDutyCycle = pumpPwmDutyCycleMin; //set duty cycle to the starting value
pumpOperationTime = millis(); //reset the pump timer to current time
previousDutyCycleIncreaseTime = millis(); //reset the duty cycle increase timer to current time
pumpActivityFlag = 1;
BLYNK_LOG("Starting water pump... (Push the hardware button to cancel)");
case 3:
if (millis() - pumpOperationTime < pumpOperationDuration){ //as long as the pump duration has not been reached...
ledcWrite(pumpPwmChannel, pumpPwmDutyCycle); //send PWM signal with current duty cycle to operate the pump
if(pumpPwmDutyCycle < pumpPwmDutyCycleMax && millis() - previousDutyCycleIncreaseTime >= dutyCycleRestTime){ //if the maximum duty cycle hasnt been reached and its time for a new increase...
previousDutyCycleIncreaseTime = millis(); //reset the duty cyle increase timer to current time
BLYNK_LOG("Current pump PWM duty cycle: %i", pumpPwmDutyCycle);
pumpPwmDutyCycle++; //slowly increase the duty cycle
if (millis() - pumpOperationTime >= pumpOperationDuration || digitalRead(buttonPin) == LOW){ //after the pump duration has been reached OR if the pump was stopped manually by pushing the button
ledcWrite(pumpPwmChannel, 0); //turn off the pump by sending a PWM signal with a duty cycle of zero
BLYNK_LOG("Water pumping has finished or was canceled manually by pushing the hardware button");
void DeepSleep() {
Blynk.disconnect();
WiFi.mode(WIFI_OFF); //this is needed to reduce power consumption during deep sleep if there is a ext0 wakeup source defined (ext1 would work without this line)
adc_power_off(); //this is needed to reduce power consumption during deep sleep if there is a ext0 wakeup source defined (ext1 would work without this line)
esp_sleep_enable_ext0_wakeup(GPIO_NUM_0, LOW); //wakup after timer runs out or pin gets pulled low by pressing the wakeup-button (GPI0_NUM_PinNumber has to be written this way)
esp_sleep_enable_timer_wakeup(sleepDuration * secondsToMikroseconds * 60); //set sleep timer (in minutes)
BLYNK_LOG("Going to sleep for %i seconds or until hardware button is pressed...", sleepDuration);
esp_deep_sleep_start(); //start deepsleep
downloadBlynk();
uploadBlynk();
batteryLevelMeasure();
waterLevelMeasure();
soilMoistureMeasure();
pumpOperation();
routine();
if(BlynkInitialized == true){
BlynkEdgent.run();
timer.run(); // Initiates BlynkTimer
int whatstate = digitalRead(LEDB);
can sombody implement the code for sending the value ( on or off ) from the buildin LED from my ESP-32 to BLYNK - its more difficult then i taught , im a newbe so
here is the code btw , the builtin LED is on pin 5 , deepsleep fuction is also in use for battery saving
#define BLYNK_TEMPLATE_ID "TMPL5_aQ_hZNJ"
#define BLYNK_TEMPLATE_NAME "Quickstart Template"
#define APP_DEBUG
//#define APP_DEBUG
//PIN Configuration
void setup(){
bootCount++;
routineState = 1;
void routine(){
routineState++;
routineState++;
case 3:
routineState++;
case 4:
routineState++;
case 5:
DeepSleep();
case 1:
else{
case 2:
Blynk.disconnect();
WiFi.disconnect();
else{
void uploadBlynk(){
case 1:
uploadBlynkState++;
case 2:
else{
blynkSyncCounter++;
blynkSyncCounter++;
blynkSyncCounter++;
blynkSyncCounter++;
blynkSyncCounter++;
blynkSyncCounter++;
blynkSyncCounter++;
blynkSyncCounter++;
blynkSyncCounter++;
blynkSyncCounter++;
blynkSyncCounter++;
blynkSyncCounter++;
blynkSyncCounter++;
blynkSyncCounter++;
blynkSyncCounter++;
case 2:
case 2:
else{
case 2:
case 1:
else{
case 2:
else{
case 3:
void DeepSleep() {
Blynk.disconnect();
downloadBlynk();
uploadBlynk();
pumpOperation();
routine();
BlynkEdgent.run();
I can.
That's an awful lot of code for a noob. Why don't you set it aside for a second and play with something smaller and learn how to do what you want. Then add it to this gigantic code.
Make a code that just does the thing you want to learn. It will be easier to learn and easier to get help.
I have no idea about Blynk.
You can keep a variable for the status of the LED. Use that variable
i believe , i try many things , but still not work
From your code:
//#define APP_DEBUG
Did you try uncommenting these ? Or did you follow the advice in line 3?
yess everything works on this project , also in Blynk , but i want to see in blynk my esp32 is online
if the esp is online the blue led goes on , so i want to use in blynk also the LED funtion so i can see its online ,
i think use some virtual pin , but then you have to adres pin 5 to a virtual pin
and send that to blynk
Is that because of some of the code you've written? Can you point out the lines that turn the led on?
Are you just not interested in doing this the faster way?
I have merged your topics due to them having too much overlap on the same subject matter @ronnys.
In the future, please only create one topic for each distinct subject matter and be careful not to cause them to converge into parallel discussions.
The reason is that generating multiple threads on the same subject matter can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Thanks in advance for your cooperation.
@ronnys …. I think as others have mentioned, you should start with basics.
Couple things i will point out as a Blynk user myself….
When using Blynk, Your void loop() should only call functions blynkedgent.run() and timer.run(). The timer.run() will call all your other functions at staggered alternate intervals (using timer.setInterval() ) in setup. If you send too many values from the device to blynk servers (using loop() ), You risk the chance of flooding the server and being disconnected.
if it is working good as you say, then the Blynk app will tell you that the device is connected and “online”.
when connected to an access point and Blynk servers, builtIN_led will fade on/off in a nice slow sinewave pattern and usually not to full brightness. Im not really sure how you can read this changing state and what benefit you would gain?
