How can I quote on this forum?
This is a text that I want to quote.
[edit]An example of how to quote is displayed below[/edit]
In order to quote myself I used this URL:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?action=post;num=1239534348;quote=0;title=PostReply
The 'quote=0;' is the important part.
I usually remember the reply number of the post I want to quote. Then I 'copy url' when holding my cursor over the 'Reply' link. Paste the URL into the adress line of my browser, then I manually insert the 'quote=num;' into the URL.
A bit of extra time, and you have a quote!
BTW thanks for that tip, makes things much closer to how they used to be(TM). Now all I need to do is make a bookmarklet to do it for me--or you know, get the YaBB board fixed. :slight_smile:
--Phil.
Isn't it easier to just copy the text you want to quote, click the quote button when replying, and paste the copied text between the quote symbols ?
Maybe "easier" but also a different result (although quoted images seem to highlight a bug). :slight_smile:
--Phil.
Here's a bookmarklet to add a quote link to each post:
javascript:for (var i in document.links) if (/;quote=\d+;title=PostReply$/.test(document.links[i].href)) document.links[i].innerHTML = 'Quote';
