#include <PCF85063A.h>
PCF85063A rtc;
time_t t;
tmElements_t tm;
Serial.begin(57600);
Serial.println(String("Resetting RTC, status: ") + rtc.reset());
Serial.println("Setting time to Tue, 08 Nov 2016 23:49:50");
/* Convert Unix timestamp to tmElements_t */
breakTime(1478648990, tm);
rtc.time_set(&tm);
/* Print human readable time */
void print_time(tmElements_t t) {
Serial.print(String("Year ") + (1970 + t.Year));
Serial.print(String(" Month ") + t.Month);
Serial.print(String(" Day ") + t.Day);
Serial.print(String(" Wday ") + t.Wday);
Serial.print(String(" Hour ") + t.Hour);
Serial.print(String(" Minute ") + t.Minute);
Serial.print(String(" Second ") + t.Second);
Serial.print("\n");
tmElements_t t;
/* Get and print current time */
rtc.time_get(&t);
print_time(t);
/* Print Unix timestamp */
Serial.print("Unix time: ");
Serial.println(makeTime(t));
Arduino: 1.8.19 (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 115200, None"
In file included from C:\Users\shanawaz\Documents\Arduino\libraries\pcf85063a-master\PCF85063A.cpp:25:0:
C:\Users\shanawaz\Documents\Arduino\libraries\pcf85063a-master\PCF85063A.h:101:19: error: 'tmElements_t' has not been declared
bool time_get(tmElements_t *now);
C:\Users\shanawaz\Documents\Arduino\libraries\pcf85063a-master\PCF85063A.h:110:19: error: 'tmElements_t' has not been declared
bool time_set(tmElements_t *new_time);
C:\Users\shanawaz\Documents\Arduino\libraries\pcf85063a-master\PCF85063A.cpp:98:21: error: 'bool PCF85063A::time_get' is not a static data member of 'class PCF85063A'
PCF85063A::time_get(tmElements_t *now)
C:\Users\shanawaz\Documents\Arduino\libraries\pcf85063a-master\PCF85063A.cpp:98:21: error: 'tmElements_t' was not declared in this scope
C:\Users\shanawaz\Documents\Arduino\libraries\pcf85063a-master\PCF85063A.cpp:98:35: error: 'now' was not declared in this scope
C:\Users\shanawaz\Documents\Arduino\libraries\pcf85063a-master\PCF85063A.cpp:99:1: error: expected ',' or ';' before '{' token
C:\Users\shanawaz\Documents\Arduino\libraries\pcf85063a-master\PCF85063A.cpp:117:21: error: 'bool PCF85063A::time_set' is not a static data member of 'class PCF85063A'
PCF85063A::time_set(tmElements_t *new_time)
C:\Users\shanawaz\Documents\Arduino\libraries\pcf85063a-master\PCF85063A.cpp:117:21: error: 'tmElements_t' was not declared in this scope
C:\Users\shanawaz\Documents\Arduino\libraries\pcf85063a-master\PCF85063A.cpp:117:35: error: 'new_time' was not declared in this scope
C:\Users\shanawaz\Documents\Arduino\libraries\pcf85063a-master\PCF85063A.cpp:118:1: error: expected ',' or ';' before '{' token
Multiple libraries were found for "TimeLib.h"
Used: C:\Users\shanawaz\Documents\Arduino\libraries\Time-master
Not used: C:\Users\shanawaz\Documents\Arduino\libraries\Time-1.6.1
Multiple libraries were found for "PCF85063A.h"
Used: C:\Users\shanawaz\Documents\Arduino\libraries\pcf85063a-master
Not used: C:\Users\shanawaz\Documents\Arduino\libraries\PCF85063A-Arduino-Library-master
exit status 1
Error compiling for board ESP32 Dev Module.
option enabled in File -> Preferences.
please help me Anyone
by using wire library
Why not use the internal rtc of the ESP32?
Did the PCF85063A example work?
We are using external RTC device and I'm testing example only but still I'm getting error.
Hi, @kalyantillu
to use structure "tmElements_t t;"
you need the Timelib.h library.
