how can i read LSM9DS0 i2c multiple byte fast?
Hello everyone ! I'm using LSM9DS0 accelerate Sensors.When the sensors are connected directly to the
Arduino DUE I get the proper accelerate readings.I set my frequency to 1600Hz and accelerate 16g.This is my code.
#include <SPI.h> // Included for SFE_LSM9DS0 library
#include <Wire.h>
#include <SFE_LSM9DS0.h>
#define LSM9DS0_XM  0x1D // Would be 0x1E if SDO_XM is LOW
#define LSM9DS0_G   0x6B // Would be 0x6A if SDO_G is LOW
LSM9DS0 dof(MODE_I2C, LSM9DS0_G, LSM9DS0_XM);
#define PRINT_RAW
#define PRINT_SPEED 1 // 500 ms between prints
unsigned long startTime;
const byte INT1XM = 3; // INT1XM tells us when accel data is ready
const byte INT2XM = 2; // INT2XM tells us when mag data is ready
const byte DRDYG  = 4; // DRDYG  tells us when gyro data is ready
float abias[3]= {0, 0, 0}, gbias[3] = {0, 0, 0};
float ax, ay, az;
float tempX[32]= {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
float tempY[32]= {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
float tempZ[32]= {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
float data1[192];
float data[3];
float g = 0 , t = 0 , u = 0;
int ii=0;
int d,i,j,k,q;
  Serial.begin(115200); // Start serial at 115200 bps
  // Use the begin() function to initialize the LSM9DS0 library.
  // You can either call it with no parameters (the easy way):
  Wire.begin();
  Wire.setClock(400000L);
  // Or call it with declarations for sensor scales and data rates:
  uint16_t status = dof.begin();
  pinMode(INT1XM, INPUT);
  pinMode(INT2XM, INPUT);
  pinMode(DRDYG,  INPUT);
  dof.setAccelScale(dof.A_SCALE_16G);
  dof.setAccelODR(dof.A_ODR_1600);
  dof.setAccelABW(dof.A_ABW_773);
  dof.calLSM9DS0(gbias, abias);
 delay(100);
  Serial.flush();
 Serial.flush();
  startTime = millis();
  dof.readAccel1();
   q = dof.data5[1];
 for( ii=0; ii<q; ii++){
    float a = (dof.tempX[ii]);
    a = a * 0.000732;
    Serial.print(a);
    Serial.print(",");
  Serial.println(startTime);
  startTime = 0 ;
while (Serial.available())
       {Serial.read();Serial.flush();
and this is part of LSM9DS0.cpp code
void LSM9DS0::readAccel1()
	uint8_t data[6] = {0, 0, 0, 0, 0, 0};
	int samples, ii, c, abc;
	c = xmReadByte(CTRL_REG0_XM);
  xmWriteByte(CTRL_REG0_XM, c | 0x40);      // Enait for change to take effect
                                // Wnable accelerometer FIFO stream mode and set watermark at 32 samples
  xmWriteByte(FIFO_CTRL_REG, 0x20 | 0x1F);  // Eable accelerometer FIFO
	delay(15);  // delay 1000 milliseconds to collect FIFO samples
	samples = (xmReadByte(FIFO_SRC_REG) & 0x1F);
	for(ii=0;ii<samples;ii++)
	xmReadBytes(OUT_X_L_A, &data[0], 6);
  tempX[ii] = ((int16_t)data[1] << 8) | data[0];
	tempY[ii] = ((int16_t)data[3] << 8) | data[2];
	tempZ[ii] = ((int16_t)data[5] << 8) | data[4];
	data5[1] = samples;
  xmWriteByte(CTRL_REG0_XM, c & ~0x40);    // Disable accelerometer FIFO
  xmWriteByte(FIFO_CTRL_REG, 0x00);       // Enable accelerometer bypass mode
Every resault's interval is about 30ms.
But my result isn't fast.It is about 718Hz.I don't know where is the problem.
Could anyone help me in this case??
