I need help regarding on EEPROM library. Based on the code below, for every 2 sec, I want to store the int for increase where it will keep increasing by 1. Then, I upload to my Arduino Nano and open Serial Monitor to let it run for about 20 seconds. The serial monitor shows that Increase Count:10
Then I unplug the Arduino Nano, closed the Serial Monitor, wait for 5 sec, then plug back to computer and turn on the Serial Monitor, then the Serial Monitor start to shows Increase Count:1
, which indicated it start to recount again from 1,2,3,4.....
I thought that EEPROM will store the last number it counted which is 10, then when I unplug and plug back it should continue to count from 10, 11, 12, .......
So I would like to ask community whether my execution code and the method is correct or not. If not, can you advice me on how I can execute it correctly. Thank you in advance!
#include <EEPROM.h>
int addr=5;
int storagedata;
int increase;
storagedata= EEPROM.read(addr);
timevalue=millis();
if (millis()-timevalue>=2000)
increase=increase+1;
EEPROM.update(addr,increase);
Serial.print("Increase Count:");
Serial.println(storagedata);
timevalue=millis();
