How can I regulate my motor with the outputs PWM
Hello good, I have the LG132M motor, at maximum power it consumes 8 volts and 2000mA, I need some component that allows me to control the maximum to minimum motor power using PWN outputs, I have used transistors but they overheat. Anyone know how I can regulate their potency?
The engine is from my toy drone, the engine is not brushless.
ratavoladora:
You are probably using the wrong transistors, but you have not told us what they are so that's only a guess.
Please make a simple pencil drawing showing how everything is connected and post a photo of the drawing.
And post your program.
...R
@ratavoladora
Moved your topic to it’s current location as it is more suitable.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
If you only need the motor to move in one direction then a transistor is the right answer. But the transistor type that you need is a logic-level MOSFET. If that's not what you're using now then change to one of those.
Steve
I’d take a look here: https://www.gammon.com.au/motors
