How can I remove the first digit of the values what my sensors print in serial?
I have a code for two DHT sensors but for some reason the serial print adds "1" before the temperature and humidity values in the case of both sensors (e.g. 123.25 C, 148.12 %).
I assume that I should use the string.remove command but I'm kinnda new in this programming field so I don't know how to put it there correctly to make it work. I tried a lot after reading the general arduino string.remove tutorials and syntax but it still does not work...
My code:
#include <DHT.h>;
#define DHTPIN1 7
#define DHTPIN2 6
DHT dht[] = {
  {DHTPIN1, DHT11},
  {DHTPIN2, DHT22},
float humidity[2];
float temperature[2];
  for (auto& sensor : dht) {
    sensor.begin();
  for (int i = 0; i < 2; i++) {
    temperature[i] = dht[i].readTemperature();
    humidity[i] = dht[i].readHumidity();
    Serial.print(F("Temperature "));
    Serial.print(i);
    Serial.println(temperature[i]);
    Serial.print(F("Humidity "));
    Serial.print(i);
    Serial.println(humidity[i]);
  delay(5000);
    Serial.print(i);
    Serial.print(i);
You are printing the array inxex before the values without a space between them
Try this
    Serial.print(i);
    Serial.print("\t");
    Serial.print(i);
    Serial.print("\t");
to add a tab between the array index and the value, or simply don't print the value of i
Thank you so much! It works now well!:slight_smile:
