How can I replace bluetooth for buttons dmd p10 matrix
How can I control the messages with buttons in dmd
I want control 16 buttons for 16 different messages
the code with bluetooth is:
#include <SPI.h>        //SPI.h must be included as DMD is written by SPI (the IDE complains otherwise)
#include <DMD.h>
#include <TimerOne.h>
#include "SystemFont5x7.h"
#include "Arial_black_16.h"
//Fire up the DMD library as dmd
#define DISPLAYS_ACROSS 4
#define DISPLAYS_DOWN 1
DMD dmd(DISPLAYS_ACROSS, DISPLAYS_DOWN);
//number max of characters in your message
#define max_char 100
char message[max_char];    // stores you message
//char mess[max_char];
char r_char;               // reads each character
byte index = 0;            // defines the position into your array
int i;
char greeting[] = "Bienvenidos";
  Interrupt handler for Timer1 (TimerOne) driven DMD refresh scanning, this gets
  called at the period set in Timer1.initialize();
void ScanDMD()
  dmd.scanDisplayBySPI();
void setup(void)
   //initialize TimerOne's interrupt/CPU usage used to scan and refresh the display
   Timer1.initialize( 5000 );           //period in microseconds to call ScanDMD. Anything longer than 5000 (5s) and you can see flicker.
   Timer1.attachInterrupt( ScanDMD );   //attach the Timer1 interrupt to ScanDMD which goes to dmd.scanDisplayBySPI()
   //clear/init the DMD pixels held in RAM
   dmd.clearScreen( true );   //true is normal (all pixels off), false is negative (all pixels on)
strcpy(message,greeting);
void loop(void)
   //check if serial is avaible an before reading a new message delete's the old message
   if(Serial.available())
        for(i=0; i<99; i++){
            message[i] = '\0';
        //resests the index
        index=0;
    //while is reading the message
    while(Serial.available() > 0){
       //the message can have up to 100 characters
       if(index < (max_char-1))
           r_char = Serial.read();      // Reads a character
           message[index] = r_char;     // Stores the character in message array
           index++;                     // Increment position
          // message[index] = '\0';       // Delete the last position
 //prepares the display to print our message
   dmd.selectFont(Arial_Black_16);
   //displays the message
   dmd.drawMarquee(message ,max_char,(32*DISPLAYS_ACROSS)-1 ,0);
   long start=millis();
   long timer=start;
   boolean ret=false;
   while(!ret)
     if ((timer+30) < millis()) {
       ret=dmd.stepMarquee(-1,0);
       timer=millis();
