How can I reset the score after the results to 0 - 0?
#include <LiquidCrystal.h>
LiquidCrystal
lcd(12,11,5,4,3,2);
char candidate_1='A';
char candidate_2='B';
int vote_1=0;
int vote_2=0;
int state_1=0;
int state_2=0;
int result=0;
int button_1=6;
int button_2=7;
int button_result=8;
//Display message
void first_display() {
lcd.setCursor(0,0);
lcd.print("1-");
lcd.print(candidate_1);
lcd.setCursor(0,1);
lcd.print("2-");
lcd.print(candidate_2);
lcd.print(" choose!");
lcd.begin(16,2);
pinMode(button_1,INPUT);
pinMode(button_2,INPUT);
pinMode(button_result,INPUT);
first_display();
state_1= digitalRead(button_1);
state_2=digitalRead(button_2);
result=digitalRead(button_result);
if(state_1==HIGH) {
vote_1++;
lcd.clear();
lcd.print(" selected");
Serial.print(candidate_1);
Serial.print(" selected");
delay(2000);
lcd.clear();
if(state_2==HIGH) {
vote_2++;
lcd.clear();
Serial.print(candidate_2);
delay(2000);
lcd.clear();
if(result==HIGH) {
lcd.clear();
lcd.print(" ");
lcd.print(vote_1);
  Serial.print("    ");
  Serial.print(vote_1);
  lcd.setCursor(0,1);
  lcd.print("    ");
  lcd.print(vote_2);
  Serial.print("    ");
  Serial.print(vote_2);
  delay(4000);
  lcd.clear();
Can you supply a bit more information relating to your question?
Paul
The easier you make it to read and copy your code the more likely it is that you will get help
Please follow the advice given in the link below when posting code , use code tags and post the code here
If you get errors when compiling please copy them from the IDE using the "Copy error messages" button and paste the clipboard here in code tags
