How can I see if Wifi connection is still alive?
I have a project that uses a MKR1000 as a simple web server and also as a client to send SMS when certain events occur. And it works fine.
However, sometimes the connection drops. For example maybe the router is reset.
How can I test (in code) to see if the connection has dropped?
And if this detects a drop, is there a clean, reliable way to restart the connection or should I just do a NVIC_SystemReset(); to restart the sketch?
Thanks!
!WL_CONNECTED is the normal way to detect a diconnected WiFi, just do a normal begin. Check the library samples to be sure, but I think that is correct. Here is a code snippet from a WiFi web server. It assumes it gets fixed magically, but you may want to count the number of tries then do a new begin.
I found another thread which seems to indicate that isn't 100% reliable. It suggested the following code that actually pings the gateway to see if it's live:
bool isWifiConnected(){
  //check connected
  if ( WiFi.status() != WL_CONNECTED) {
    return false;
  //test ping the gateway
  IPAddress gip = WiFi.gatewayIP();
  int pingResult = WiFi.ping(gip);
  if (pingResult < 0) {
    return false;
  //connected
  return true;
Side note: I did a forum search expecting to find something like this, but apparently didn't search on the correct keywoard. That thread popped up on the side of this one!
Thanks!
Ok, I haven't seen that particular example but it sounds like a good idea. If a failure is detected, I would still recommend restarting only the WiFi, not the entire board.
