How can I send a single serial (processing & Arduino)
Hey guys I am using a Kinect to control the on and off of a LED. it shoots 1’s and 0’s to Arduino.
The only problem is it’s continues, using the printing I can see it shoots millions of 1’s and 0’s at a time
how can I make it so it doesn’t send the inputs continuously?
here is my processing code:
import org.openkinect.processing.*;
import processing.serial.*;
Kinect kinect;
Serial myPort;
PImage img;
  size(6, 6);
  kinect = new Kinect(this);
  kinect.initDepth();
  img = createImage(kinect.width, kinect.height, RGB);
  String portName = Serial.list()[9]; //change the 0 to a 1 or 2 etc. to match your port
  myPort = new Serial(this, portName, 9600);
void draw() {
  background(0);
  img.loadPixels();
  int[] depth = kinect.getRawDepth();
  float sumX =0;
  float sumY =0;
  float totalPixels = 0;
  int skip = 50;
  for (int x = 0; x < kinect.width; x+=skip) {
    for (int y = 0; y < kinect.height; y+=skip) {
      int offset = x + y * kinect.width;
      int d = depth[offset];
      //if int );
      if ( d  > 300 && d < 500) {
        img.pixels[offset] = color(255, 255, 255);
        myPort.write('1');         //send a 1
        println("1");
        img.pixels[offset] = color(0);
        myPort.write('0');
          img.updatePixels();
          image(img, 0, 0);
And of course the Arduino code:
 char val; // Data received from the serial port
 int ledPin = 13; // Set the pin to digital I/O 13
   pinMode(ledPin, OUTPUT); // Set pin as OUTPUT
   Serial.begin(9600); // Start serial communication at 9600 bps
   if (Serial.available())
   { // If data is available to read,
     val = Serial.read(); // read it and store it in val
   if (val == '1')
   { // If 1 was received
     digitalWrite(ledPin, HIGH); // turn the LED on
     digitalWrite(ledPin, LOW); // otherwise turn it off
   delay(10); // Wait 10 milliseconds for next reading
Thanks everyone
     if (val == '1')
only call digitalWrite() when you receive something valid from Serial
how can I make it so it doesn't send the inputs continuously?
Don't process the image data over and over. The Processing app has a setup() function, for one time stuff, and a draw() function for things that are to happen over and over. Don't do stuff in the over and over function that you want done one time.
