How can I send integer from arduino to another arduino by FS1000A / XY-MK-5V 433
I'm trying to send and receive some data from arduino to another arduino and I'm using arduino UNO and FS1000A / XY-MK-5V 433Mhz TX/RX Modules.
For transmitting I use the library VirtualWire and It works very well for this code:
#include <VirtualWire.h>
// Initialize the IO and ISR
vw_setup(2000); // Bits per sec
char msg[7] = {'h','e','l','l','o',' ','!'};
vw_send((uint8_t *)msg, 7);
vw_wait_tx(); // Wait until the whole message is gone
I was wondering if I want to send some string or int data how I can do that.
I tried to use it for string data but I couldn't because the Input of function vw_send(...) is char and I couldn't use int or string.
finally I run this code:
char msg[11]="Hello there";
vw_send((uint8_t *)msg, 11);
and I could send Hello there !, but I'm looking for the correct way for sending string and int.
Read this or that or something else.... many more for example (adding an antenna and proper power for the devices will help with distance)
