I connected a microphone and speaker to 2 ESP32s and was able to hear my voice reproduced by the speaker from the microphone using an ESP32. I was also able to send audio signals between them, but I was not able to comprehend the spoken words. I assume it is because I am sending the current value from the analogRead function and since the data rate of the ESP Now link is lower than the adc sampling rate, much information is lost in the transmission.
I tried creating an array of 1000 values and sending one array at a time using the code below but its not working for me. I will appreciate your help, I need to send higher quality audio between the 2 ESP32s.
#include <esp_now.h>
#include <WiFi.h>
// REPLACE WITH THE MAC Address of your receiver
uint8_t broadcastAddress[] = {0x7C, 0x9E, 0xBD, 0x47, 0x92, 0x4C}; //MAC Address
float A;
const int Max = 1000;
//Define Sent Message
typedef struct test_message {
float A[Max];
} test_message;
test_message tx; //Sent Message
test_message rx; // Received Message
// Transmitting Callback
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
char macStr[18];
// Copies the sender mac address to a string
snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x:", mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]);
// Receiving Callback
void OnDataRecv(const uint8_t * mac, const uint8_t *incomingData, int len) {
memcpy(&rx, incomingData, sizeof(rx));
// Set device as a Wi-Fi Station
WiFi.mode(WIFI_STA);
// Init ESP-NOW
if (esp_now_init() != ESP_OK) {
// Serial.println("Error initializing ESP-NOW");
return;
esp_now_register_recv_cb(OnDataRecv);
// Once ESPNow is successfully Init, we will register for Send CB to
// get the status of Trasnmitted packet
esp_now_register_send_cb(OnDataSent);
// Register peer
esp_now_peer_info_t peerInfo;
memcpy(peerInfo.peer_addr, broadcastAddress, 6);
peerInfo.channel = 0;
peerInfo.encrypt = false;
// Add peer
if (esp_now_add_peer(&peerInfo) != ESP_OK){
// Serial.println("Failed to add peer");
return;
// Register for a callback function that will be called when data is received
for (int i=0; i<Max; i++){
tx.A[i] = analogRead(35);
esp_err_t result = esp_now_send(0, (uint8_t *) &tx, sizeof(test_message));
dacWrite(25, rx.A[i]);
Serial.println(rx.A[i]);
Thanks in Advance.
