How can i send serial data from arduino via bluetooth?
I'm trying to build a pedometer that can detects the acceleration changes from (x,y,z) directions. I can get these values but my main problem is how to send these data via bluetooth? I'm using an app which is ArduDroid from playstore.
When i write a value to Serial and after pressing send button, i can see the value on the app screen. But i can't get the values what i want(accelerometer value like(-1,12)). BT kit is HC-06. Here is the ss:
And here is an example code below:
#include <SoftwareSerial.h>
int bluetoothTx = 1;
int bluetoothRx = 0;
SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
  //Setup usb serial connection to computer
  //Setup Bluetooth serial connection to android
  bluetooth.begin(115200);
  bluetooth.print("$$");
  delay(100);
  bluetooth.println("U,9600,N");
  bluetooth.begin(9600);
  //Read from bluetooth and write to usb serial
  if(bluetooth.available())
    char toSend = (char)bluetooth.read();
    toSend='a"
    Serial.print(toSend);
  //Read from usb serial to bluetooth
  if(Serial.available())
    char toSend = (char)Serial.read();
    bluetooth.print(toSend);
Give up now. You CAN NOT do software serial on the hardware serial pins, while also using them as hardware serial pins.
i can get data from android but there is an other error while using threads. but i fixed as you said
