How can I set a signal range for standard firmatta
Hi, I have combined a standard firmata with heartbeat sensor code in an attempt to turn a device on or off in ableton.
I am able to turn the sensor on, but due to the signal being so high I can’t turn it off.
Is there a way to do this? how would I go about introducing an if statement to control this?
Is there some other way?
my connections are
VIN - 5V
SDA - A4
SCL - A5
GND - GND
I have attached the code
I would very much appreciate some help on this!
Thankyou
heartbeat_firmatta.ino (27.5 KB)
Am I headed in the right direction?
I dont think I was actually getting a response from ableton with my original code.
I have merged simpler versions of the code now, I still cannot use the sensor as an input but Im wondering if this is because the two codes I merged use serial 9600 and 57600.
Would I be looking at millis and storing values in “long”?
This is what i’ve got, i can make a piezo react to ableton but not the heart sensor.
 * Firmata is a generic protocol for communicating with microcontrollers
 * from software on a host computer. It is intended to work with
 * any host computer software package.
 * To download a host software package, please click on the following link
 * to open the list of Firmata client libraries in your default browser.
 * https://github.com/firmata/arduino#firmata-client-libraries
/* This firmware supports as many analog ports as possible, all analog inputs,
 * four PWM outputs, and two with servo support.
 * This example code is in the public domain.
#include <Servo.h>
#include <Firmata.h>
//below is sensor code
#include <Wire.h>
#include "MAX30105.h"
MAX30105 particleSensor;
#define debug Serial //Uncomment this line if you're using an Uno or ESP
//#define debug SerialUSB //Uncomment this line if you're using a SAMD21
 * GLOBAL VARIABLES
/* servos */
Servo servo9, servo10; // one instance per pin
/* analog inputs */
int analogInputsToReport = 0; // bitwise array to store pin reporting
int analogPin = 0; // counter for reading analog pins
/* timer variables */
unsigned long currentMillis;     // store the current value from millis()
unsigned long previousMillis;    // for comparison with currentMillis
 * FUNCTIONS
void analogWriteCallback(byte pin, int value)
  switch (pin) {
    case 9: servo9.write(value); break;
    case 10: servo10.write(value); break;
    case 3:
    case 5:
    case 6:
    case 11: // PWM pins
      analogWrite(pin, value);
// sets bits in a bit array (int) to toggle the reporting of the analogIns
void reportAnalogCallback(byte pin, int value)
  if (value == 0) {
    analogInputsToReport = analogInputsToReport & ~ (1 << pin);
  else { // everything but 0 enables reporting of that pin
    analogInputsToReport = analogInputsToReport | (1 << pin);
  // TODO: save status to EEPROM here, if changed
 * SETUP()
  Firmata.setFirmwareVersion(FIRMATA_FIRMWARE_MAJOR_VERSION, FIRMATA_FIRMWARE_MINOR_VERSION);
  Firmata.attach(ANALOG_MESSAGE, analogWriteCallback);
  Firmata.attach(REPORT_ANALOG, reportAnalogCallback);
  servo9.attach(9);
  servo10.attach(10);
  Firmata.begin(57600);
debug.begin(9600);
  debug.println("MAX30105 Basic Readings Example");
  // Initialize sensor
  if (particleSensor.begin() == false)
    debug.println("MAX30105 was not found. Please check wiring/power. ");
    while (1);
  particleSensor.setup(); //Configure sensor. Use 6.4mA for LED drive
 * LOOP()
    debug.print("] IR[");
  debug.print(particleSensor.getIR());
  debug.println();
 // above debug is sensor code
  while (Firmata.available())
    Firmata.processInput();
  currentMillis = millis();
  if (currentMillis - previousMillis > 20) {
    previousMillis += 20;                   // run this every 20ms
    for (analogPin = 0; analogPin < TOTAL_ANALOG_PINS; analogPin++) {
      if ( analogInputsToReport & (1 << analogPin) )
        Firmata.sendAnalog(analogPin, analogRead(analogPin));
@20toms
Use one serial rate or the other but using two would be no good unless one was a soft serial rate which I dont think you want.
Other post/duplicate DELETED
Please do NOT cross post / duplicate as it wastes peoples time and efforts to have more than one post for a single topic.
Continued cross posting could result in a time out from the forum.
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
