bm6dzr
June 20, 2015, 1:05am
1
I wrote this code,it's working.
But how to run 4 times than stop every thing?
I tried "for loop",but not working....
#include <EEPROM.h>
byte led1 = 10;
byte led2 = 11;
byte led3 = 12;
byte button1 = 2;
byte button2 = 3;
//define the available states that we can have for this sketch
enum States{
stateOne, stateTwo};
//add more states as needed
States mState = stateOne; //we start out in this machine state
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(button1, INPUT_PULLUP);
pinMode(button2, INPUT_PULLUP);
digitalWrite(led1,LOW);
digitalWrite(led2,LOW);
digitalWrite(led3,LOW);
} //END of setup()
switch (mState)
case stateOne:
if(digitalRead(button1))
digitalWrite(led1,HIGH);
delay(2000);
digitalWrite(led2,HIGH);
mState = stateTwo;
case stateTwo:
if(digitalRead(button2))
digitalWrite(led3,HIGH);
mState = stateOne;
default:
// default code goes here
} //END of switch(mState)
system
June 20, 2015, 1:16am
2
enum States{
How about making the state names mean something. stateOne doesn't mean anything. stateTwo means just as little. stateEnd could be added, in which nothing happens. At the appropriate point, transition to stateEnd, whose case statement causes nothing to happen visibly.
LarryD
June 20, 2015, 1:17am
3
Please describe your project?
If you are serious about programming, delay() is not the way to do delays.
See BlinkWithoutDelay.
bm6dzr
June 20, 2015, 2:37am
4
the project is
I want control two solenoid valve with 2 magnetic sensor
beginning,magnet at position1(sensor1)
sensor1 on
than led1(coil1) on
delay 1 sec.
than led1 off
delay 2 sec.
than led2(coil2) on
delay 1 sec.
led2 off
the magnet will touch sensor2
until sensor2 on
led3(coil3) on
dealy 1 sec
led3 off
than magnet come back to touch sensor1
I want the loop run 4 times than stop every thing
thank you~
system
June 20, 2015, 2:38am
5
Then create a for loop in setup(), and leave loop() empty.
bm6dzr
June 20, 2015, 3:19am
6
PaulS:
like this?
#include <EEPROM.h>
byte led1 = 10;
byte led2 = 11;
byte led3 = 12;
byte button1 = 2;
byte button2 = 3;
enum States{
int i=0
for(i=0;i<4;i++){}
} //END of setup()
switch (mState)
case stateOne:
delay(2000);
mState = stateTwo;
case stateTwo:
mState = stateOne;
default:
Empty for() loop is empty.
If you want to do something 4 times, then put it into the body of that for() loop. Don't put it into the loop() function.
The loop() function can be empty (but it must exist.)
bm6dzr:
like this?
Did you leave loop empty, as instructed?
