No matter how I try and post my code it says its over 9000 char even when I check that its under that limit… So I cut out 2 parts that shouldnt matter when it comes to understanding my setup. I cut out the #defines of the pins
int passwordPos1UpState = 0; // current state of the 1st pos up button
int passwordPos2UpState = 0;
int passwordPos3UpState = 0;
int passwordPos4UpState = 0;
int passwordPos5UpState = 0;
int passwordPos1DownState = 0; // current state of the 1st pos Down button
int passwordPos2DownState = 0;
int passwordPos3DownState = 0;
int passwordPos4DownState = 0;
int passwordPos5DownState = 0;
int passwordSubmitState = 0; // current state of the submit button
int lastPasswordPos1UpState = 0; // previous state of the 1st pos up button
int lastPasswordPos2UpState = 0;
int lastPasswordPos3UpState = 0;
int lastPasswordPos4UpState = 0;
int lastPasswordPos5UpState = 0;
int lastPasswordPos1DownState = 0; // previous state of the 1st pos Down button
int lastPasswordPos2DownState = 0;
int lastPasswordPos3DownState = 0;
int lastPasswordPos4DownState = 0;
int lastPasswordPos5DownState = 0;
int lastPasswordSubmitState = 0; // previous state of the submit button
char displayVals[5] = {0,0,0,0,0};
char positionVals[5][6] = {
{0,0,0,0,0,0},
{0,0,0,0,0,0},
{0,0,0,0,0,0},
{0,0,0,0,0,0},
{0,0,0,0,0,0}
int currentPositionPos[] = {0,0,0,0,0};
char validWords[35][5] = {
{'a','b','o','u','t'},
{'a','f','t','e','r'},
{'a','g','a','i','n'},
{'b','e','l','o','w'},
{'c','o','u','l','d'},
{'e','v','e','r','y'},
{'f','i','r','s','t'},
{'f','o','u','n','d'},
{'g','r','e','a','t'},
{'h','o','u','s','e'},
{'l','a','r','g','e'},
{'l','e','a','r','n'},
{'n','e','v','e','r'},
{'o','t','h','e','r'},
{'p','l','a','c','e'},
{'p','l','a','n','t'},
{'p','o','i','n','t'},
{'r','i','g','h','t'},
{'s','m','a','l','l'},
{'s','o','u','n','d'},
{'s','p','e','l','l'},
{'s','t','i','l','l'},
{'s','t','u','d','y'},
{'t','h','e','i','r'},
{'t','h','e','r','e'},
{'t','h','e','s','e'},
{'t','h','i','n','g'},
{'t','h','i','n','k'},
{'t','h','r','e','e'},
{'w','a','t','e','r'},
{'w','h','e','r','e'},
{'w','h','i','c','h'},
{'w','o','r','l','d'},
{'w','o','u','l','d'},
{'w','r','i','t','e'}
pinMode(PIN_PASSWORD_LED_FIN, OUTPUT);
pinMode(PIN_PASSWORD_BUTTON_1, INPUT);
pinMode(PIN_PASSWORD_BUTTON_2, INPUT);
pinMode(PIN_PASSWORD_BUTTON_3, INPUT);
pinMode(PIN_PASSWORD_BUTTON_4, INPUT);
pinMode(PIN_PASSWORD_BUTTON_5, INPUT);
pinMode(PIN_PASSWORD_BUTTON_6, INPUT);
pinMode(PIN_PASSWORD_BUTTON_7, INPUT);
pinMode(PIN_PASSWORD_BUTTON_8, INPUT);
pinMode(PIN_PASSWORD_BUTTON_9, INPUT);
pinMode(PIN_PASSWORD_BUTTON_10, INPUT);
pinMode(PIN_PASSWORD_BUTTON_SUBMIT, INPUT);
randomSeed(analogRead(0));
genCorrectLetters();
genRandLetters(0);
genRandLetters(1);
genRandLetters(2);
genRandLetters(3);
genRandLetters(4);
setInitDisplayLetters(0);
setInitDisplayLetters(1);
setInitDisplayLetters(2);
setInitDisplayLetters(3);
setInitDisplayLetters(4);
Serial.println("Display Letters");
for(int i = 0; i < 5; i++)
Serial.print(displayVals[i]);
Serial.println("");
Serial.println("Correct Letters");
Serial.print(positionVals[i][0]);
Serial.println("");
Serial.println("POS1 Letters");
for(int i = 0; i < 6; i++)
Serial.print(positionVals[0][i]);
Serial.println("");
Serial.println("POS2 Letters");
Serial.print(positionVals[1][i]);
Serial.println("");
Serial.println("POS3 Letters");
Serial.print(positionVals[2][i]);
Serial.println("");
Serial.println("POS4 Letters");
Serial.print(positionVals[3][i]);
Serial.println("");
Serial.println("POS5 Letters");
Serial.print(positionVals[4][i]);
Serial.println("");
void setInitDisplayLetters(int p)
byte randomLetter = random(0,6);
displayVals[p] = positionVals[p][randomLetter];
currentPositionPos[p] = randomLetter;
void setDisplayLetters(int bp, bool pm)
int currentLetterPos = currentPositionPos[bp];
int nextLetterPos;
if (pm==true) {
if (currentLetterPos==5) {
nextLetterPos = 0;
currentPositionPos[bp] = 0;
nextLetterPos = currentLetterPos++;
currentPositionPos[bp]++;
} else if (pm==false) {
if (currentLetterPos==0) {
nextLetterPos = 5;
currentPositionPos[bp] = 5;
nextLetterPos = currentLetterPos--;
currentPositionPos[bp]--;
displayVals[bp] = positionVals[bp][nextLetterPos];
updatePasswordDisplay();
void updatePasswordDisplay()
Serial.println("");
void genCorrectLetters()
byte randomWord = random(0,35);
int positionPopulated = 0;
while (positionPopulated<5)
char letter = validWords[randomWord][positionPopulated];
positionVals[positionPopulated][0] = letter;
positionPopulated ++;
void genRandLetters(int p)
int generated=1;
while (generated<6)
byte randomValue = random(0, 26);
char letter = randomValue + 'a';
positionVals[p][generated] = letter;
generated ++;
passwordPos1UpState = digitalRead(PIN_PASSWORD_BUTTON_1);
passwordPos2UpState = digitalRead(PIN_PASSWORD_BUTTON_2);
passwordPos3UpState = digitalRead(PIN_PASSWORD_BUTTON_3);
passwordPos4UpState = digitalRead(PIN_PASSWORD_BUTTON_4);
passwordPos5UpState = digitalRead(PIN_PASSWORD_BUTTON_5);
passwordPos1DownState = digitalRead(PIN_PASSWORD_BUTTON_6);
passwordPos2DownState = digitalRead(PIN_PASSWORD_BUTTON_7);
passwordPos3DownState = digitalRead(PIN_PASSWORD_BUTTON_8);
passwordPos4DownState = digitalRead(PIN_PASSWORD_BUTTON_9);
passwordPos5DownState = digitalRead(PIN_PASSWORD_BUTTON_10);
passwordSubmitState = digitalRead(PIN_PASSWORD_BUTTON_SUBMIT);
//UP BUTTONS//
// compare passwordPos1UpState to previous state
if (passwordPos1UpState != lastPasswordPos1UpState) {
if (passwordPos1UpState == HIGH) {
setDisplayLetters(0, true);
lastPasswordPos1UpState = passwordPos1UpState;
// compare passwordPos2UpState to previous state
if (passwordPos2UpState != lastPasswordPos2UpState) {
if (passwordPos2UpState == HIGH) {
setDisplayLetters(1, true);
lastPasswordPos2UpState = passwordPos2UpState;
// compare passwordPos3UpState to previous state
if (passwordPos3UpState != lastPasswordPos3UpState) {
if (passwordPos3UpState == HIGH) {
setDisplayLetters(2, true);
lastPasswordPos3UpState = passwordPos3UpState;
// compare passwordPos4UpState to previous state
if (passwordPos4UpState != lastPasswordPos4UpState) {
if (passwordPos4UpState == HIGH) {
setDisplayLetters(3, true);
lastPasswordPos4UpState = passwordPos4UpState;
// compare passwordPos5UpState to previous state
if (passwordPos5UpState != lastPasswordPos5UpState) {
if (passwordPos5UpState == HIGH) {
setDisplayLetters(4, true);
lastPasswordPos5UpState = passwordPos5UpState;
//DOWN BUTTONS//
// compare passwordPos1DownState to previous state
if (passwordPos1DownState != lastPasswordPos1DownState) {
if (passwordPos1DownState == HIGH) {
setDisplayLetters(0, false);
lastPasswordPos1DownState = passwordPos1DownState;
// compare passwordPos2DownState to previous state
if (passwordPos2DownState != lastPasswordPos2DownState) {
if (passwordPos2DownState == HIGH) {
setDisplayLetters(1, false);
lastPasswordPos2DownState = passwordPos2DownState;
// compare passwordPos3DownState to previous state
if (passwordPos3DownState != lastPasswordPos3DownState) {
if (passwordPos3DownState == HIGH) {
setDisplayLetters(2, false);
lastPasswordPos3DownState = passwordPos3DownState;
// compare passwordPos4DownState to previous state
if (passwordPos4DownState != lastPasswordPos4DownState) {
if (passwordPos4DownState == HIGH) {
setDisplayLetters(3, false);
lastPasswordPos4DownState = passwordPos4DownState;
// compare passwordPos5DownState to previous state
if (passwordPos5DownState != lastPasswordPos5DownState) {
if (passwordPos5DownState == HIGH) {
setDisplayLetters(4, false);
lastPasswordPos5DownState = passwordPos5DownState;
