Hi
Experts i found something exciting i dont know how its possible recently i design "Flyback Isolated DC-DC Converter" and its FBT (Flyback Transformer) specs below
turns and wire gauge details (i hope it will to understand it )
core used is EE25/EPC25
when i connect this tf with my "Flyback Isolated DC-DC Converter" without considering the starting and ending point it work
s fine without heating so whats the plz help me to solve this myth
As per my understanding (can be wrong) but is it really matter that while connecting wire of input and load then the result is same
as i tested it and working fine
one problem is that is heating the components and auz widing giving 60v as same input volt is applied at primary whats thar guys
this pics my professor send me to explain
Again it is not clear but I think by the issue of tf (transformer) starting and end point, you mean the polarity of the windings, usually indicated by a dot on schematic diagrams.
I'm having difficulty understanding your problem description.
Anyway, if you are having problems with heating, it may be that you are driving the primary circuit with a frequency which is too low. If you have shorted one of the secondary coils, there will be also a heating effect.
This is anyway not my expert area. I suggest you include a schematic diagram in this thread and maybe someone else can help.
I'm not an expert on transformers but you probably need more turns for more inductance, or perhaps higher switching frequency.
If you are studying transformers I assume you understand inductive reactance and resistance. The wire resistance will be very low so if the there is not enough inductance, or it the frequency is too low you'll get excess current and heating.
I like this article "flyback converters for dummies"; url below. There is "An Inductor test bench" described where you can check the coil current by oscilloscope under conditions close to the end application. If the inductance is too small or the switch on-time too long than the ferrite core may saturate and the current may increase sharply. flayback converters for dummies
Dear first of all thank you so much from my heart for reply I'm saying that when i connected flyback transformer output is fine everything is fine but i can able to find the problem that why its primary winding components getting heating up
Does the uc3843 chip get warm ? Its maximum voltage is 28v, and you have said that you have measured 30v. The 10 ohm resistor in the auxilliary circuit (winding N2) looks very low to me. I could imagine that the uc3843 protection diodes are cutting in. You could measure the current. The chip itself needs less than 25mA on quick scanning of the data sheet.
The UCx84x has a VCC supply voltage clamp of 34 V typical, but the absolute maximum value for VCC from a low-impedance source is 30 V.
For applications that have a higher input voltage than the recommended VCC voltage, place a resistor in series with VCC to increase the source impedance.
