The Sketch uses 1626 bytes (5%) of the program storage space. The maximum is 32256 bytes.
Global variables use 192 bytes (9%) of dynamic memory, leaving 1856 bytes for local variables. The maximum is 2048 bytes.
What is the problem? That isn't an error message.
How can you solve? ... you ignore it. It is not a problem.
Are you facing any problem after uploading? Ain't your setup showing the desired result?
