How can I stop my robotic car when nrf24l01 disconnected
Hi guys.
I am using two nrf24l01 to control my robotic car with wireless joystick.
Right the problem is that when my car is moving and somehow the car and joystick gets out of contact then the car keeps moving and I have to physically stop the car.
Below is my car receiver code. Please tell me what should I add in the coding that when connection is lost my car stops immediately.
Thanks
Include RadioHead ReliableDatagram & NRF24 Libraries
#include <RHReliableDatagram.h>
#include <RH_NRF24.h>
// Include dependant SPI Library
#include <SPI.h>
// Define addresses for radio channels
#define CLIENT_ADDRESS 1
#define SERVER_ADDRESS 2
// Motor A Connections
int enA = 9;
int in1 = 14;
int in2 = 4;
// Motor B Connections
int enB = 5;
int in3 = 7;
int in4 = 6;
// Create an instance of the radio driver
RH_NRF24 RadioDriver;
// Sets the radio driver to NRF24 and the server address to 2
RHReliableDatagram RadioManager(RadioDriver, SERVER_ADDRESS);
// Define a message to return if values received
uint8_t ReturnMessage[] = "JoyStick Data Received";
// Define the Message Buffer
uint8_t buf[RH_NRF24_MAX_MESSAGE_LEN];
// Setup Serial Monitor
// Set all the motor control pins to outputs
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
// Initialize RadioManager with defaults - 2.402 GHz (channel 2), 2Mbps, 0dBm
if (!RadioManager.init())
Serial.println("init failed");
if (RadioManager.available())
// Wait for a message addressed to us from the client
uint8_t len = sizeof(buf);
uint8_t from;
if (RadioManager.recvfromAck(buf, &len, &from))
//Serial Print the values of joystick
//Serial.print("got request from : 0x");
//Serial.print(from, HEX);
//Serial.print(": MotorA = ");
//Serial.print(buf[0]);
//Serial.print(" MotorB = ");
//Serial.print(buf[1]);
//Serial.print(" Dir = ");
//Serial.println(buf[2]);
// Set Motor Direction
if (buf[2] == 1)
// Motors are backwards
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
digitalWrite(in3, LOW);
digitalWrite(in4, HIGH);
}else{
// Motors are forwards
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
// Drive Motors
analogWrite(enA, buf[1]);
analogWrite(enB, buf[0]);
// Send a reply back to the originator client, check for error
if (!RadioManager.sendtoWait(ReturnMessage, sizeof(ReturnMessage), from))
Serial.println("sendtoWait failed");
Perhaps you need to send a heartbeat message from your transmitter, say once a second. If your receiver misses 2 or 3 heartbeat messages then you stop the car.
