How can I store text messages and list them using GSM module?
I’m trying to make a mobile phone using a GSM module “sim900A”, I was able to make calls and send text messages but I want to make a list of the messages sent from the mobile to the GSM and to be able to read them. What should I add to the code to do this?
This is a link for the tutorial I have followed for more info:
/*THIS TUTORIAL USED GSM SIM900A MINI V3.9.2
  Connect 5VT to D9 and 5VR to D10
  Feed GSM SIM900A with Arduino's 5V
  Code by IDAYU SABRI - MYBOTIC
#include <SoftwareSerial.h>
SoftwareSerial mySerial(9, 10);
char msg;
char call;
  mySerial.begin(9600);   // Setting the baud rate of GSM Module
  Serial.begin(9600);    // Setting the baud rate of Serial Monitor (Arduino)
  Serial.println("GSM SIM900A BEGIN");
  Serial.println("Enter character for control option:");
  Serial.println("h : to disconnect a call");
  Serial.println("i : to receive a call");
  Serial.println("s : to send message");
  Serial.println("c : to make a call");
  Serial.println("e : to redial");
  delay(100);
  if (Serial.available()>0)
   switch(Serial.read())
    case 's':
      SendMessage();
    case 'c':
      MakeCall();
    case 'h':
      HangupCall();
    case 'e':
      RedialCall();
    case 'i':
      ReceiveCall();
 if (mySerial.available()>0)
 Serial.write(mySerial.read());
void SendMessage()
  mySerial.println("AT+CMGF=1");    //Sets the GSM Module in Text Mode
  delay(1000);  // Delay of 1000 milli seconds or 1 second
  mySerial.println("AT+CMGS=\"+60XXXXXXXXX\"\r"); // Replace x with mobile number
  mySerial.println("sim900a sms");// The SMS text you want to send
  delay(100);
   mySerial.println((char)26);// ASCII code of CTRL+Z
void ReceiveMessage()
  mySerial.println("AT+CNMI=2,2,0,0,0"); // AT Command to recieve a live SMS
    msg=mySerial.read();
    Serial.print(msg);
void MakeCall()
  mySerial.println("ATD+60XXXXXXXXX;"); // ATDxxxxxxxxxx; -- watch out here for semicolon at the end!!
  Serial.println("Calling  "); // print response over serial port
void HangupCall()
  mySerial.println("ATH");
  Serial.println("Hangup Call");
void ReceiveCall()
  mySerial.println("ATA");
    call=mySerial.read();
    Serial.print(call);
void RedialCall()
  mySerial.println("ATDL");
  Serial.println("Redialing");
You’ve probably got 2 choices.
  1. Store the message on the Arduino at the time of sending.
  2. Attempt to find an AT command for the gsm module which gives access to the stored data.
AT commands:
