I'm just learning Arduino and i've got a DC Motor & IR Receiver connected. It's working fine if i press the button once but i can't figure out how to keep the motor spinning if i hold the button down as the REPEAT command is the same numbers.
I figured i would store the last code sent and check if the repeat command and last code match but it doesn't seem to be working and can't figure out why.
#include <IRremote.h>
int IRpin = 11; // pin for the IR sensor
IRrecv irrecv(IRpin);
decode_results results;
int lastCode;
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(13, OUTPUT);
irrecv.enableIRIn(); // Enable IR Receiver.
if
(irrecv.decode(&results)) {
Serial.println(results.value);
irrecv.resume();
Serial.println("Last Code is set to: ");
Serial.write(lastCode);
if(results.value== 16748655 || (results.value== 4294967295 && lastCode== 16748655)) // Your ON button value
digitalWrite(8, HIGH);
digitalWrite(7, LOW);
analogWrite(9, 255);
analogWrite(9, 0);
lastCode= 16748655;
else if(results.value == 16769055 || (results.value== 4294967295 && lastCode== 16769055)) // Your OFF button value
digitalWrite(8, LOW);
digitalWrite(7, HIGH);
analogWrite(9, 0);
lastCode= 16769055;
lastCode= 16769055;
An int is only sixteen bits.
That value is twenty four.
Use unsigned long instead
AWOL:
lastCode= 16769055;
Wow that's all it was, thanks for much for the quicky reply.
1 more thing, Where im outputting the value of last code, How can i get it to be on a single line in the serial so it just shows as "The last code was: xx" rather then having a new line after the string, I only know abit of PHP and in that i just use "This is a string". $variable; but that doesn't seem to work.
Serial.print(F("Last Code is set to: "));
Serial.println(lastCode);
Thanks, that's all working perfectly. I've decided to add some LEDs but struggling to find out how to detect when ive let go of the button on the IR Controller i want to turn the LED off.
At the moment it turns on fine when i press it but once i let go it stays on.
How can i detect when the button is no longer being press?
int ledOne = 5;
unsigned long lastCode;
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
pinMode(ledOne, OUTPUT);
if (irrecv.decode(&results)) {
irrecv.resume();
//Serial.print(F("Last Code is set to: "));
//Serial.println(lastCode);
delay(100);
analogWrite(9, 0);
lastCode= 16748655;
digitalWrite(ledOne, HIGH);
results.value=0;
delay(100);
analogWrite(9, 0);
lastCode= 16769055;
irrecv.decode() will return false when no button is being pressed. There is NO value sent that says that you released the button.
PaulS:
Thanks, I tried this and the LED lights up for a couple seconds then turns off, Have i mis-typed something?
if(irrecv.decode(&results) == false) {
digitalWrite(ledOne, LOW);
Yes. You left out setup() and loop(). This is not http://snippets-r-us.com. You should pay them a visit with your snippet.
int ledOne = 5;
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
if (!irrecv.decode(&results))
else // Decode was successful
// Handle REPEAT code
if (results.value != 4294967295UL)
lastCode = results.value;
irrecv.resume();
// Serial.print(F("Last Code is set to: "));
// Serial.println(lastCode);
switch (lastCode)
case 16748655UL: // Your ON button value
delay(100);
analogWrite(9, 0);
case 16769055UL: // Your OFF button value
delay(100);
analogWrite(9, 0);
