Hello,
I would like to store number as like a=50 when i receive "50" from serial monitor.
How can i do that?
Thanks.
Hello,
How can i do that?
Thanks.
Like this?
int yourNumber= atoi(yourString);
kind regards,
Jos
Very basic character capture and number conversion example.
//zoomkat 7-30-10 serial servo test
//type servo position 0 to 180 in serial monitor
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo; // create servo object to control a servo
myservo.attach(9);
Serial.println("servo-test"); // so I can keep track of what is loaded
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the String readString
delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
Serial.println(readString); //so you can see the captured String
int n = readString.toInt(); //convert readString into a number
myservo.write(n);
readString="";
String readString;
Honestly I think there is a better way of doing this.Using String Objects just for this purpose is to much overkill.
Why not char arrays?
They are more lite and more efficient for what the user wants to do.
Manipulating char arrays is one of the skills that every programmer should know.
