I have a number of air quality sensors :
pms5003: for PM2.5
BME680
GPS
SD card
RTC: real time
i want to write program for match them but i do not have an knowledge
i have ARDUINO uno and ESP32 WEMOS and i do not know which one is better.
I can work with each one alone and get data but I do not know how I can write the program all together .
Your question is vague. Hope this might answer your question.
You need to structure your code to perform the task at hand. You will understand this structure when start looking at examples and even more codes.(Most of the good resources online explain the structure in detail).
For a beginner, you would put the code you want to run once in the
"void setup()" of the code (usually initializing SD Card and the Sensors.)
put the code you want to run continually in the
void loop() ( usually the readings of the sensors, doing calculations and performing tasks when the sensor reading hit a certain value(like running a motor)).
Initialize Serial connection, defining the pins as INPUT and OUTPUT and more
Code for Reading the Sensors,
Code for reading GPS
Code for RTC
Code for Storing all the read values of the sensors
GPS, once acquired, can be used to set a real time clock or correct it if the error exceeds some threshold.
reading your sensors is independent of clock updates.
presumably reading the sensors doesn't need to be continuous, perhaps only as often as every 10 minutes. those values can be stored on an SD card along with a timestamp from the RTC.
