How can I take the average value of MAX30102 and display it every minute instead of getting many values per second?
This is my first project using Arduino IDE. I used example 7 in Sparkfun Max3010x library and displayed the results on my screen. However, I'm getting so many outline values and it changes every second. I need to make it stable and get the results to change every minute once by taking the average of the values per minute.
#include <Wire.h>
#include "MAX30105.h"
#include "spo2_algorithm.h"
#include <SPI.h>
#include <LiquidCrystal.h>
#include "SPIFFS.h"
#include <TFT_eSPI.h>
#include "heartRate.h"
TFT_eSPI tft = TFT_eSPI();
MAX30105 particleSensor;
#define MAX_BRIGHTNESS 255
#if defined(__AVR_ATmega328P__) || defined(__AVR_ATmega168__)
//Arduino Uno doesn't have enough SRAM to store 100 samples of IR led data and red led data in 32-bit format
//To solve this problem, 16-bit MSB of the sampled data will be truncated. Samples become 16-bit data.
uint16_t irBuffer[100]; //infrared LED sensor data
uint16_t redBuffer[100];  //red LED sensor data
#else
uint32_t irBuffer[100]; //infrared LED sensor data
uint32_t redBuffer[100];  //red LED sensor data
#endif
int32_t bufferLength; //data length
int32_t spo2; //SPO2 value
int8_t validSPO2; //indicator to show if the SPO2 calculation is valid
int32_t heartRate; //heart rate value
int8_t validHeartRate; //indicator to show if the heart rate calculation is valid
byte pulseLED = 11; //Must be on PWM pin
byte readLED = 13; //Blinks with each data read
  Serial.begin(115200); // initialize serial communication at 115200 bits per second:
  tft.begin();
  tft.setRotation(0);
  pinMode(pulseLED, OUTPUT);
  pinMode(readLED, OUTPUT);
  // Initialize sensor
  if (!particleSensor.begin(Wire, I2C_SPEED_FAST)) //Use default I2C port, 400kHz speed
    Serial.println(F("MAX30105 was not found. Please check wiring/power."));
    while (1);
  Serial.read();
  byte ledBrightness = 60; //Options: 0=Off to 255=50mA
  byte sampleAverage = 4; //Options: 1, 2, 4, 8, 16, 32
  byte ledMode = 2; //Options: 1 = Red only, 2 = Red + IR, 3 = Red + IR + Green
  byte sampleRate = 100; //Options: 50, 100, 200, 400, 800, 1000, 1600, 3200
  int pulseWidth = 411; //Options: 69, 118, 215, 411
  int adcRange = 4096; //Options: 2048, 4096, 8192, 16384
  particleSensor.setup(ledBrightness, sampleAverage, ledMode, sampleRate, pulseWidth, adcRange); //Configure sensor with these settings
  bufferLength = 100; //buffer length of 100 stores 4 seconds of samples running at 25sps
  delay(2000); //Required by this device to function properly
  //read the first 100 samples, and determine the signal range
  for (byte i = 0 ; i < bufferLength ; i++)
    while (particleSensor.available() == false) //do we have new data?
      particleSensor.check(); //Check the sensor for new data
    redBuffer[i] = particleSensor.getRed();
    irBuffer[i] = particleSensor.getIR();
    particleSensor.nextSample(); //We're finished with this sample so move to next sample
    Serial.print(F("red="));
    Serial.print(redBuffer[i], DEC);
    Serial.print(F(", ir="));
    Serial.println(irBuffer[i], DEC);
  //calculate heart rate and SpO2 after first 100 samples (first 4 seconds of samples)
  maxim_heart_rate_and_oxygen_saturation(irBuffer, bufferLength, redBuffer, &spo2, &validSPO2, &heartRate, &validHeartRate);
  //Continuously taking samples from MAX30102.  Heart rate and SpO2 are calculated every 1 second
  while (1)
    //dumping the first 25 sets of samples in the memory and shift the last 75 sets of samples to the top
    for (byte i = 25; i < 100; i++)
      redBuffer[i - 25] = redBuffer[i];
      irBuffer[i - 25] = irBuffer[i];
    //take 25 sets of samples before calculating the heart rate.
    for (byte i = 75; i < 100; i++)
      digitalWrite(readLED, !digitalRead(readLED)); //Blink onboard LED with every data read
      //send samples and calculation result to terminal program through UART
      Serial.print(irBuffer[i], DEC);
      Serial.print(F(", HR="));
      Serial.print(heartRate, DEC);
      Serial.print(F(", HRvalid="));
      Serial.print(validHeartRate, DEC);
      Serial.print(F(", SPO2="));
      Serial.print(spo2, DEC);
      Serial.print(F(", SPO2Valid="));
      Serial.println(validSPO2, DEC);
    showScrn(); //display
    //After gathering 25 new samples recalculate HR and SP02
void showScrn(){
  tft.fillScreen(TFT_BLACK);
  tft.setTextColor(TFT_WHITE, TFT_BLACK);
  tft.setFreeFont(&Orbitron_Light_24);
  tft.drawLine(0, 35, 250, 35, TFT_WHITE);
  tft.setCursor(0,60);
  tft.println("PO:");
  tft.setCursor(50, 60);
  tft.print(spo2);
  tft.setCursor(0,90);
  tft.println("HR:");
  tft.setCursor(50, 90);
  tft.print(heartRate);
Hi @muskar
welcome to the arduino-Forum.
As this is your first Arduino-Porject I assume that you know (yet) not much about programming.
You will learn programming with the help of the Arduino-Forum for sure.
But it is not a thing of 2 hours to know all important things. It takes more time than 2 hours.
Here I recommend to make a fundamental descision:
  1. going on with learning programming which will take dozens of hours
  2. abandon this project immitiately and switch over to a device you can buy off the shelf
Something inbetween like get some hints, try some modifications ask again get some hints
modify again tinkering around for hours almost no progress IMHO is unsatisfying.
So my recommendation is to work through this tutorial to learn
important basics that apply to EACH and EVERY project
Take a look into this tutorial:
Arduino Programming Course
It is easy to understand and has a good mixture between explaining important concepts and example-codes to get you going. So give it a try and report your opinion about this tutorial.
and give the duck a go
best regards Stefan
