Here is entire code if it will help. As far as wiring I am a retired industrial electrician so I know it's wired correctly, and after I push "lightOff" button everything works fine. The timer "fanLedBlink" does the same thing.
#include <LedFlasher.h>
int LDR = A0; //analog pin to which LDR is connected, here we set it to 0 so it means A0
int LDRValue = 0; //that's a variable to store LDR values
int light_sensitivity = 150; //This is the approx value of light surrounding your LDR
const byte holdLightLed = 22;
const byte holdfanLed = 24;
const byte lightLed = 50; //light on led
const byte lightLedBlink = 36; //light on led BLACK
const byte lightRelay = 12; //turn on light
const int fanLed = 52;//
const int fanLedBlink = 38;// fan on led
const int fanRelay = 11; //turn on fan
const byte thermostatOverRideLed = 40;//thermostst override on ledRED
const byte thermostatOverRideRelay = 10; //short thermostat output
const byte tripSensedLed = 42; //tripSensed led
const byte tripSensedPauseLed = 44; //tripSensed led
const byte LDRled = 40;
const int pin_yRelay = 12;
const int pin_lightFanRetime = 31;
const int pin_tripSensed = 13; //laser sensor input
const int pin_tripSensedPause = 35; //laser sensor input bypass
const int pin_fanOn = 14;//button to turn off fan YELLOW
const int pin_fanOn2 = 25;//button to turn off fan
const int pin_fanOff = 16;//button to turn off fan YELLOW
const int pin_theromOverRide = 41; //button to short thermostat output RED
const int pin_lightOn = 43;//button to turn on light
const int pin_lightOn2 = 23;//button to turn on light
const int pin_lightOff = 15;//button to turn off light
//unsigned long currentMillis6; // variables to track millis()
//unsigned long currentMillis5; // variables to track millis()
//unsigned long currentMillis4; // variables to track millis()
unsigned long currentMillis; // variables to track millis()
unsigned long previousMillis6 = 0;
unsigned long previousMillis5 = 0;
unsigned long previousMillis4 = 0;
unsigned long previousMillis3 = 0;
unsigned long previousMillis2 = 0;
unsigned long previousMillis = 0;
unsigned long interval5 =600000UL;
unsigned long interval4 = 420UL;
unsigned long interval = 600000UL;
unsigned long interval2 = 600000UL;
unsigned long interval3 = 2500UL;
byte FanLedBlink = 0;
byte LightLedBlink = 0;
byte tripSensedPause = 0;
byte timer7Timing = 0;
byte timer6Timing = 0;
byte timer5Timing = 0;
byte timer4Timing = 0;
byte timer3Timing = 0;
byte timer2Timing = 0;
byte timer1Timing = 0;
bool pushed_yRelay = false;
bool pushed_lightFanRetime = false;
bool pushed_tripSensed = false;
bool pushed_tripSensedPause = false;
bool pushed_fanOn = false;
bool pushed_fanOn2 = false;
bool pushed_fanOff = false;
bool pushed_theromOverRide = false;
bool pushed_lightOn = false;
bool pushed_lightOn2 = false;
bool pushed_lightOff = false;
int lightRelayState = LOW;
int val = 0; // variable to store the read value
void setup ()//(void)
// pinMode (yRelay, OUTPUT);
pinMode (lightLedBlink, OUTPUT);
pinMode (lightLed, OUTPUT);
pinMode (lightRelay, OUTPUT);
pinMode (fanLedBlink, OUTPUT);
pinMode (fanLed, OUTPUT);
pinMode (holdfanLed, OUTPUT);
pinMode (fanRelay, OUTPUT);
pinMode (thermostatOverRideLed, OUTPUT);
pinMode (thermostatOverRideRelay, OUTPUT);
pinMode (tripSensedLed, OUTPUT);
pinMode (tripSensedPauseLed, OUTPUT);
pinMode (holdLightLed, OUTPUT);
pinMode (LDRled, OUTPUT);
pinMode (pin_lightFanRetime, INPUT_PULLUP);
pinMode (pin_tripSensed, INPUT_PULLUP);
pinMode (pin_tripSensedPause, INPUT_PULLUP);
pinMode (pin_fanOff, INPUT_PULLUP);
pinMode (pin_theromOverRide, INPUT_PULLUP);
pinMode (pin_fanOn, INPUT_PULLUP);
pinMode (pin_fanOn2, INPUT_PULLUP);
pinMode (pin_lightOn, INPUT_PULLUP);
pinMode (pin_lightOn2, INPUT_PULLUP);
pinMode (pin_lightOff, INPUT_PULLUP);
void loop ()
bool prev_yRelay = pushed_yRelay;
bool prev_lightFanRetime = pushed_lightFanRetime;
bool prev_tripSensed = pushed_tripSensed;
bool prev_tripSensedPause = pushed_tripSensedPause;
bool prev_fanOn = pushed_fanOn;
bool prev_fanOn2 = pushed_fanOn2;
bool prev_fanOff = pushed_fanOff;
bool prev_theromOverRide = pushed_theromOverRide;
bool prev_lightOff = pushed_lightOff;
bool prev_lightOn = pushed_lightOn;
bool prev_lightOn2 = pushed_lightOn2;
pushed_yRelay = digitalRead (pin_yRelay) == LOW;
pushed_lightFanRetime = digitalRead (pin_lightFanRetime) == LOW;
pushed_theromOverRide = digitalRead (pin_theromOverRide) == LOW;
pushed_tripSensed = digitalRead (pin_tripSensed) == LOW;
pushed_tripSensedPause = digitalRead (pin_tripSensedPause) == LOW;
pushed_fanOn = digitalRead (pin_fanOn) == LOW;
pushed_fanOn2 = digitalRead (pin_fanOn2) == LOW;
pushed_fanOff = digitalRead (pin_fanOff) == LOW;
pushed_lightOn = digitalRead (pin_lightOn) == LOW;
pushed_lightOn2 = digitalRead (pin_lightOn2) == LOW;
pushed_lightOff = digitalRead (pin_lightOff) == LOW;
LDRValue = analogRead(LDR);
Serial.println (LDRValue);
//if(currentMillis - previousMillis4 > interval4) {
// save the last time you blinked the LED
previousMillis4 = currentMillis;
digitalWrite (lightLedBlink, LOW);
if (pushed_tripSensedPause)// thermostat override pushed
digitalWrite(tripSensedPauseLed, HIGH); // turn on light led
previousMillis3 = currentMillis;
timer3Timing = 1;
// delay(6000);
if ((currentMillis - previousMillis3 > interval3) && (timer3Timing == 1)) {
digitalWrite(tripSensedPauseLed, LOW); // turn on light led
timer3Timing = 0;
if (pushed_tripSensed) {
digitalWrite(fanRelay, HIGH);//turn on the relay
digitalWrite(fanLed, HIGH);//turn on the led
previousMillis5 = currentMillis;
timer5Timing = 1;
if ((currentMillis - previousMillis5 > interval5) && (timer5Timing == 1)) {
digitalWrite(fanRelay, LOW);//turn on the relay
digitalWrite(fanLed, LOW);//turn on the led
timer5Timing = 0;
if ((LDRValue < light_sensitivity) && (pushed_tripSensed) && (timer3Timing == 0) || (pushed_lightFanRetime))
// low light and LASER tripped and timer flag reset OR retime pushed
digitalWrite(lightRelay, HIGH); // turn on light led
digitalWrite(lightLed, HIGH); // turn on light led
timer1Timing = 1;
// delay(6000);
if ((currentMillis - previousMillis > interval) && (timer1Timing == 1)) {
digitalWrite(lightRelay, LOW);//turn off the relay
digitalWrite(lightLed, LOW); // turn off light led
digitalWrite(fanRelay, LOW);//turn off the relay
digitalWrite(fanLed, LOW);//turn off the led
timer1Timing = 0;
if (pushed_theromOverRide)// thermostat override pushed
digitalWrite(thermostatOverRideRelay, HIGH);//turn thermostat override relay on
digitalWrite(thermostatOverRideLed, HIGH);//turn thermostat override relay led on
previousMillis2 = currentMillis;
timer2Timing = 1;
// delay(6000);
if ((currentMillis - previousMillis2 > interval2) && (timer2Timing == 1)) {
digitalWrite(thermostatOverRideRelay, LOW);//turn thermostat override relay off
digitalWrite(thermostatOverRideLed, LOW);//turn thermostat override relay led off
timer2Timing = 0;
val = digitalRead(pin_tripSensed); // read the input pin
digitalWrite(tripSensedLed, !val); // sets the LED to the button's value
if (pushed_lightOn) {
digitalWrite (holdLightLed, LOW);
digitalWrite (lightRelay, HIGH);
timer6Timing = 1;
if (pushed_lightOff) {
digitalWrite (holdLightLed, HIGH);
digitalWrite (lightRelay, LOW);
digitalWrite (lightLed, LOW);
timer6Timing = 0;
if (pushed_lightOn2){ {
timer6Timing = 1;
if (timer6Timing == 1);
digitalWrite ( lightLedBlink, (millis() % 1200 < 125) ? 5000 : 0 ); // flash LED at 2Hz
if (pushed_fanOn) {
digitalWrite (holdfanLed, LOW);
digitalWrite (fanRelay, HIGH);
if (pushed_fanOff) {
digitalWrite (holdfanLed, HIGH);
digitalWrite (fanRelay, LOW);
digitalWrite (fanLed, LOW);
if (pushed_fanOn2) {
digitalWrite ( fanLedBlink, (millis() % 1200 < 125) ? 5000 : 0 ); // flash LED at 2Hz
