How can I trigger animations with this code?
I found this code that lets me play tones in harmony.
#include <Adafruit_GFX.h>    // Core graphics library
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_SSD1306.h>
#include "Spaceship.h"
#include "Functions.h"
// Arduino polyphonic FM sound
// * 31250 Hz sampling rate
// * 9-bit resolution
// * 4-fold polyphony (4 different tones can play simulatenously)
// * FM-synthesis with time-varying modulation amplitude
// * ADSR envelopes
// * 12 preset instruments
// Through PWM with timer1, sound is generated on pin 9
// instrument-select button on A5
// 18 sound keys on the remaining i/o pins
// by Rolf Oldeman Feb 2019
// Licence CC BY-NC-SA 2.5 https://creativecommons.org/licenses/by-nc-sa/2.5/
//instrument definitions
#define ninstr 12           //   piano xlphn guitar cmbll bell funky vibr metal violin bass trumpt harm
unsigned int ldness[ninstr]  = {   64,   64,   64,   64,   64,   64,   64,   64,   64,   64,   64,   64}; // loudness
unsigned int pitch0[ninstr]  = {   12,   12,   12,   12,   24,   24,    0,   12,   24,   12,   12,   24}; // pitch of key0
unsigned int ADSR_a[ninstr]  = { 4096, 8192, 8192, 8192, 4096,  512,  512, 8192,  128,  128,  256,  256}; // attack parameter
unsigned int ADSR_d[ninstr]  = {    8,   32,   16,   16,    8,   16,   16,    8,   16,   16,   64,   32}; // decay parameter
unsigned int ADSR_s[ninstr]  = {    0,    0,    0,    0,    0,    0,    0,    0,  240,  240,  192,  192}; // sustain parameter
unsigned int ADSR_r[ninstr]  = {   64,  128,   32,   32,   16,   32,   32,   32,   32,   32,   64,   64}; // release parameter
unsigned int FM_inc[ninstr]  = {  256,  512,  768,  400,  200,   96,  528,  244,  256,  128,   64,  160}; // FM frequency wrt pitch
unsigned int FM_a1[ninstr]  =  {  128,  512,  512, 1024,  512,    0, 1024, 2048,  256,  256,  384,  256}; // FM amplitude start
unsigned int FM_a2[ninstr]  =  {   64,    0,  128,  128,  128,  512,  768,  512,  128,  128,  256,  128}; // FM amplitude end
unsigned int FM_dec[ninstr]  = {   64,  128,  128,  128,   32,  128,  128,  128,  128,  128,   64,   64}; // FM decay
//define the pitch2key mapping
#define keyC4   0
#define keyC4s  1
#define keyD4   2
#define keyD4s  3
#define keyE4   4
#define keyF4   5
#define keyF4s  6
#define keyG4   7
#define keyG4s  8
#define keyA4   9
#define keyA4s 10
#define keyB4  11
#define keyC5  12
#define keyC5s 13
#define keyD5  14
#define keyD5s 15
#define keyE5  16
#define keyF5  17
#define nokey 255
#define instrkey 254
//define the pin to key mapping for 18-key keyboard
#define pinD0 keyC5    //Arduino pin D0
#define pinD1 keyB4    //Arduino pin D1
#define pinD2 keyA4s   //Arduino pin D2
#define pinD3 keyA4    //Arduino pin D3
#define pinD4 keyG4s   //Arduino pin D4
#define pinD5 keyG4    //Arduino pin D5
#define pinD6 keyF4s   //Arduino pin D6
#define pinD7 keyF4    //Arduino pin D7
#define pinB0 keyE4    //Arduino pin D8
#define pinB1 nokey    //Arduino pin D9  used for audio out
#define pinB2 keyD4s   //Arduino pin D10
#define pinB3 keyD4    //Arduino pin D11
#define pinB4 keyC4s   //Arduino pin D12
#define pinB5 keyC4    //Arduino pin D13
#define pinB6 nokey    //Arduino pin D14 inexistent
#define pinB7 nokey    //Arduino pin D15 inexistent
#define pinC0 keyC5s   //Arduino pin A0
#define pinC1 keyD5    //Arduino pin A1
#define pinC2 keyD5s   //Arduino pin A2
#define pinC3 keyE5    //Arduino pin A2
#define pinC4 keyF5    //Arduino pin A3
#define pinC5 instrkey //Arduino pin A4
#define pinC6 nokey    //Arduino pin A5 inexistent
#define pinC7 nokey    //Arduino pin A6 inexistent
//set up array with sine values in signed 8-bit numbers
const float pi = 3.14159265;
char sine[256];
void setsine() {
  for (int i = 0; i < 256; ++i) {
    sine[i] = (sin(2 * 3.14159265 * (i + 0.5) / 256)) * 128;
//setup frequencies/phase increments, starting at C3=0 to B6. (A4 is defined as 440Hz)
unsigned int tone_inc[48];
void settones() {
  for (byte i=0; i<48; i++){
    tone_inc[i]= 440.0 * pow(2.0, ( (i-21) / 12.0)) * 65536.0 / (16000000.0/512) + 0.5;
byte butstatD=0;
byte butstatB=0;
byte butstatC=0;
byte prevbutstatD=0;
byte prevbutstatB=0;
byte prevbutstatC=0;
byte instr=0;
  //disable all inerrupts to avoid glitches
  noInterrupts();
  //setup the array with sine values
  setsine();
  //setup array with tone frequency phase increments
  settones();
  //Set a fast PWM signal on TIMER1A, 9-bit resolution, 31250Hz
  pinMode(9, OUTPUT);
  TCCR1A = 0B10000010; //9-bit fast PWM
  TCCR1B = 0B00001001;
  //setup pins for input with pull-up
  if(pinD0 != nokey){DDRD &=~(1<<0);PORTD |=(1<<0);};
  if(pinD1 != nokey){DDRD &=~(1<<1);PORTD |=(1<<1);};
  if(pinD2 != nokey){DDRD &=~(1<<2);PORTD |=(1<<2);};
  if(pinD3 != nokey){DDRD &=~(1<<3);PORTD |=(1<<3);};
  if(pinD4 != nokey){DDRD &=~(1<<4);PORTD |=(1<<4);};
  if(pinD5 != nokey){DDRD &=~(1<<5);PORTD |=(1<<5);};
  if(pinD6 != nokey){DDRD &=~(1<<6);PORTD |=(1<<6);};
  if(pinD7 != nokey){DDRD &=~(1<<7);PORTD |=(1<<7);};
  if(pinB0 != nokey){DDRB &=~(1<<0);PORTB |=(1<<0);};
  if(pinB1 != nokey){DDRB &=~(1<<1);PORTB |=(1<<1);};
  if(pinB2 != nokey){DDRB &=~(1<<2);PORTB |=(1<<2);};
  if(pinB3 != nokey){DDRB &=~(1<<3);PORTB |=(1<<3);};
  if(pinB4 != nokey){DDRB &=~(1<<4);PORTB |=(1<<4);};
  if(pinB5 != nokey){DDRB &=~(1<<5);PORTB |=(1<<5);};
  if(pinB6 != nokey){DDRB &=~(1<<6);PORTB |=(1<<6);};
  if(pinB7 != nokey){DDRB &=~(1<<7);PORTB |=(1<<7);};
  if(pinC0 != nokey){DDRC &=~(1<<0);PORTC |=(1<<0);};
  if(pinC1 != nokey){DDRC &=~(1<<1);PORTC |=(1<<1);};
  if(pinC2 != nokey){DDRC &=~(1<<2);PORTC |=(1<<2);};
  if(pinC3 != nokey){DDRC &=~(1<<3);PORTC |=(1<<3);};
  if(pinC4 != nokey){DDRC &=~(1<<4);PORTC |=(1<<4);};
  if(pinC5 != nokey){DDRC &=~(1<<5);PORTC |=(1<<5);};
  if(pinC6 != nokey){DDRC &=~(1<<6);PORTC |=(1<<6);};
  if(pinC7 != nokey){DDRC &=~(1<<7);PORTC |=(1<<7);};
  //store button setting at startup
  butstatD = PIND;
  butstatB = PINB;
  butstatC = PINC;
//initialize the main parameters of the pulse length setting
#define nch 4 //number of channels that can produce sound simultaneously
unsigned int phase[nch]  = {0,0,0,0};
int          inc[nch]    = {0,0,0,0};
byte         amp[nch]    = {0,0,0,0};
unsigned int FMphase[nch]= {0,0,0,0};
unsigned int FMinc[nch]  = {0,0,0,0};
unsigned int FMamp[nch]  = {0,0,0,0};
// main function (forced inline) to update the pulse length
inline void setPWM() __attribute__((always_inline));
inline void setPWM() {
  //wait for the timer to complete loop
  while ((TIFR1 & 0B00000001) == 0);
  //Clear(!) the overflow bit by writing a 1 to it
  TIFR1 |= 0B00000001;
  //increment the phases of the FM
  FMphase[0] += FMinc[0];
  FMphase[1] += FMinc[1];
  FMphase[2] += FMinc[2];
  FMphase[3] += FMinc[3];
  //increment the phases of the note
  phase[0] += inc[0];
  phase[1] += inc[1];
  phase[2] += inc[2];
  phase[3] += inc[3];
  //calculate the output value and set pulse width for timer2
  int val = sine[(phase[0]+sine[FMphase[0]>>8]*FMamp[0]) >> 8] * amp[0];
  val += sine[(phase[1]+sine[FMphase[1]>>8]*FMamp[1]) >> 8] * amp[1];
  val += sine[(phase[2]+sine[FMphase[2]>>8]*FMamp[2]) >> 8] * amp[2];
  val += sine[(phase[3]+sine[FMphase[3]>>8]*FMamp[3]) >> 8] * amp[3];
  //set the pulse length
  OCR1A = val/128 + 256;
//properties of each note played
byte         iADSR[nch]     = {0, 0, 0, 0};
unsigned int envADSR[nch]   = {0, 0, 0, 0};
unsigned int ADSRa[nch]     = {0, 0, 0, 0};
unsigned int ADSRd[nch]     = {0, 0, 0, 0};
unsigned int ADSRs[nch]     = {0, 0, 0, 0};
unsigned int ADSRr[nch]     = {0, 0, 0, 0};
byte         amp_base[nch]  = {0, 0, 0, 0};
unsigned int inc_base[nch]  = {0, 0, 0, 0};
unsigned int FMa0[nch]      = {0, 0, 0, 0};
int          FMda[nch]      = {0, 0, 0, 0};
unsigned int FMinc_base[nch]= {0, 0, 0, 0};
unsigned int FMdec[nch]     = {0, 0, 0, 0};
unsigned int FMexp[nch]     = {0, 0, 0, 0};
unsigned int FMval[nch]     = {0, 0, 0, 0};
byte         keych[nch]     = {0, 0, 0, 0};
unsigned int tch[nch]       = {0, 0, 0, 0};
// main loop. Duration of loop is determined by number of setPWM calls
// Each setPWMcall corresponds to 512 cylcles=32mus
// Tloop= 32mus * #setPWM. #setPWM=15 gives Tloop=0.48ms
  //read and interpret input buttons
  prevbutstatD = butstatD;
  prevbutstatB = butstatB;
  prevbutstatC = butstatC;
  butstatD = PIND;
  butstatB = PINB;
  butstatC = PINC;
  byte keypressed = nokey;
  byte keyreleased = nokey;
  if(butstatD!=prevbutstatD){
    if ( pinD0!=nokey and (butstatD & (1<<0)) == 0 and (prevbutstatD & (1<<0)) >  0 ) keypressed  = pinD0;
while ( pinD0!=nokey and (butstatD & (1<<0)) == 0 and (prevbutstatD & (1<<0)) >  0 ) SpaceshipLoop();
    if ( pinD0!=nokey and (butstatD & (1<<0)) >  0 and (prevbutstatD & (1<<0)) == 0 ) keyreleased = pinD0;
    if ( pinD1!=nokey and (butstatD & (1<<1)) == 0 and (prevbutstatD & (1<<1)) >  0 ) keypressed  = pinD1;
    if ( pinD1!=nokey and (butstatD & (1<<1)) >  0 and (prevbutstatD & (1<<1)) == 0 ) keyreleased = pinD1;
    if ( pinD2!=nokey and (butstatD & (1<<2)) == 0 and (prevbutstatD & (1<<2)) >  0 ) keypressed  = pinD2;
    if ( pinD2!=nokey and (butstatD & (1<<2)) >  0 and (prevbutstatD & (1<<2)) == 0 ) keyreleased = pinD2;
    if ( pinD3!=nokey and (butstatD & (1<<3)) == 0 and (prevbutstatD & (1<<3)) >  0 ) keypressed  = pinD3;
    if ( pinD3!=nokey and (butstatD & (1<<3)) >  0 and (prevbutstatD & (1<<3)) == 0 ) keyreleased = pinD3;
    if ( pinD4!=nokey and (butstatD & (1<<4)) == 0 and (prevbutstatD & (1<<4)) >  0 ) keypressed  = pinD4;
    if ( pinD4!=nokey and (butstatD & (1<<4)) >  0 and (prevbutstatD & (1<<4)) == 0 ) keyreleased = pinD4;
    if ( pinD5!=nokey and (butstatD & (1<<5)) == 0 and (prevbutstatD & (1<<5)) >  0 ) keypressed  = pinD5;
    if ( pinD5!=nokey and (butstatD & (1<<5)) >  0 and (prevbutstatD & (1<<5)) == 0 ) keyreleased = pinD5;
    if ( pinD6!=nokey and (butstatD & (1<<6)) == 0 and (prevbutstatD & (1<<6)) >  0 ) keypressed  = pinD6;
    if ( pinD6!=nokey and (butstatD & (1<<6)) >  0 and (prevbutstatD & (1<<6)) == 0 ) keyreleased = pinD6;
    if ( pinD7!=nokey and (butstatD & (1<<7)) == 0 and (prevbutstatD & (1<<7)) >  0 ) keypressed  = pinD7;
    if ( pinD7!=nokey and (butstatD & (1<<7)) >  0 and (prevbutstatD & (1<<7)) == 0 ) keyreleased = pinD7;
  if(butstatB!=prevbutstatB){
    if ( pinB0!=nokey and (butstatB & (1<<0)) == 0 and (prevbutstatB & (1<<0)) >  0 ) keypressed  = pinB0;
    if ( pinB0!=nokey and (butstatB & (1<<0)) >  0 and (prevbutstatB & (1<<0)) == 0 ) keyreleased = pinB0;
    if ( pinB1!=nokey and (butstatB & (1<<1)) == 0 and (prevbutstatB & (1<<1)) >  0 ) keypressed  = pinB1;
    if ( pinB1!=nokey and (butstatB & (1<<1)) >  0 and (prevbutstatB & (1<<1)) == 0 ) keyreleased = pinB1;
    if ( pinB2!=nokey and (butstatB & (1<<2)) == 0 and (prevbutstatB & (1<<2)) >  0 ) keypressed  = pinB2;
    if ( pinB2!=nokey and (butstatB & (1<<2)) >  0 and (prevbutstatB & (1<<2)) == 0 ) keyreleased = pinB2;
    if ( pinB3!=nokey and (butstatB & (1<<3)) == 0 and (prevbutstatB & (1<<3)) >  0 ) keypressed  = pinB3;
    if ( pinB3!=nokey and (butstatB & (1<<3)) >  0 and (prevbutstatB & (1<<3)) == 0 ) keyreleased = pinB3;
    if ( pinB4!=nokey and (butstatB & (1<<4)) == 0 and (prevbutstatB & (1<<4)) >  0 ) keypressed  = pinB4;
    if ( pinB4!=nokey and (butstatB & (1<<4)) >  0 and (prevbutstatB & (1<<4)) == 0 ) keyreleased = pinB4;
    if ( pinB5!=nokey and (butstatB & (1<<5)) == 0 and (prevbutstatB & (1<<5)) >  0 ) keypressed  = pinB5;
    if ( pinB5!=nokey and (butstatB & (1<<5)) >  0 and (prevbutstatB & (1<<5)) == 0 ) keyreleased = pinB5;
    if ( pinB6!=nokey and (butstatB & (1<<6)) == 0 and (prevbutstatB & (1<<6)) >  0 ) keypressed  = pinB6;
    if ( pinB6!=nokey and (butstatB & (1<<6)) >  0 and (prevbutstatB & (1<<6)) == 0 ) keyreleased = pinB6;
    if ( pinB7!=nokey and (butstatB & (1<<7)) == 0 and (prevbutstatB & (1<<7)) >  0 ) keypressed  = pinB7;
    if ( pinB7!=nokey and (butstatB & (1<<7)) >  0 and (prevbutstatB & (1<<7)) == 0 ) keyreleased = pinB7;
  if(butstatC!=prevbutstatC){
    if ( pinC0!=nokey and (butstatC & (1<<0)) == 0 and (prevbutstatC & (1<<0)) >  0 ) keypressed  = pinC0;
    if ( pinC0!=nokey and (butstatC & (1<<0)) >  0 and (prevbutstatC & (1<<0)) == 0 ) keyreleased = pinC0;
    if ( pinC1!=nokey and (butstatC & (1<<1)) == 0 and (prevbutstatC & (1<<1)) >  0 ) keypressed  = pinC1;
    if ( pinC1!=nokey and (butstatC & (1<<1)) >  0 and (prevbutstatC & (1<<1)) == 0 ) keyreleased = pinC1;
    if ( pinC2!=nokey and (butstatC & (1<<2)) == 0 and (prevbutstatC & (1<<2)) >  0 ) keypressed  = pinC2;
    if ( pinC2!=nokey and (butstatC & (1<<2)) >  0 and (prevbutstatC & (1<<2)) == 0 ) keyreleased = pinC2;
    if ( pinC3!=nokey and (butstatC & (1<<3)) == 0 and (prevbutstatC & (1<<3)) >  0 ) keypressed  = pinC3;
    if ( pinC3!=nokey and (butstatC & (1<<3)) >  0 and (prevbutstatC & (1<<3)) == 0 ) keyreleased = pinC3;
    if ( pinC4!=nokey and (butstatC & (1<<4)) == 0 and (prevbutstatC & (1<<4)) >  0 ) keypressed  = pinC4;
    if ( pinC4!=nokey and (butstatC & (1<<4)) >  0 and (prevbutstatC & (1<<4)) == 0 ) keyreleased = pinC4;
    if ( pinC5!=nokey and (butstatC & (1<<5)) == 0 and (prevbutstatC & (1<<5)) >  0 ) keypressed  = pinC5;
    if ( pinC5!=nokey and (butstatC & (1<<5)) >  0 and (prevbutstatC & (1<<5)) == 0 ) keyreleased = pinC5;
    if ( pinC6!=nokey and (butstatC & (1<<6)) == 0 and (prevbutstatC & (1<<6)) >  0 ) keypressed  = pinC6;
    if ( pinC6!=nokey and (butstatC & (1<<6)) >  0 and (prevbutstatC & (1<<6)) == 0 ) keyreleased = pinC6;
    if ( pinC7!=nokey and (butstatC & (1<<7)) == 0 and (prevbutstatC & (1<<7)) >  0 ) keypressed  = pinC7;
    if ( pinC7!=nokey and (butstatC & (1<<7)) >  0 and (prevbutstatC & (1<<7)) == 0 ) keyreleased = pinC7;
  //while (keypressed = pinD0){
   // SpaceshipLoop();
  setPWM(); //#1
  //change instrument if instrument select button is pressed
  if ( keypressed==instrkey) {
    instr++;
    if (instr>=ninstr) instr=0;
    keypressed=keyA4;
  if (keyreleased==instrkey) keyreleased=keyA4;
  setPWM(); //#2
  //find the best channel to start a new note
  byte nextch = 255;
  //first check if the key is still being played
  if (iADSR[0] > 0 and keypressed == keych[0])nextch = 0;
  if (iADSR[1] > 0 and keypressed == keych[1])nextch = 1;
  if (iADSR[2] > 0 and keypressed == keych[2])nextch = 2;
  if (iADSR[3] > 0 and keypressed == keych[3])nextch = 3;
  //then check for an empty channel
  if (nextch == 255) {
    if (iADSR[0] == 0)nextch = 0;
    if (iADSR[1] == 0)nextch = 1;
    if (iADSR[2] == 0)nextch = 2;
    if (iADSR[3] == 0)nextch = 3;
  //otherwise use the channel with the longest playing note
    nextch = 0;
    if (tch[0] > tch[nextch])nextch = 0;
    if (tch[1] > tch[nextch])nextch = 1;
    if (tch[2] > tch[nextch])nextch = 2;
    if (tch[3] > tch[nextch])nextch = 3;
  setPWM(); //#3
  //initiate new note if needed
  if (keypressed != nokey) {
    phase[nextch]=0;
    amp_base[nextch] = ldness[instr];
    inc_base[nextch] = tone_inc[pitch0[instr]+keypressed];
    ADSRa[nextch]=ADSR_a[instr];
    ADSRd[nextch]=ADSR_d[instr];
    ADSRs[nextch]=ADSR_s[instr]<<8;
    ADSRr[nextch]=ADSR_r[instr];
    iADSR[nextch] = 1;
    FMphase[nextch]=0;
    FMinc_base[nextch] = ((long)inc_base[nextch]*FM_inc[instr])/256;
    FMa0[nextch] = FM_a2[instr];
    FMda[nextch] = FM_a1[instr]-FM_a2[instr];
    FMexp[nextch]=0xFFFF;
    FMdec[nextch]=FM_dec[instr];
    keych[nextch] = keypressed;
    tch[nextch] = 0;
  setPWM(); //#4
  //stop a note if the button is released
  if (keyreleased != nokey) {
    if (keych[0] == keyreleased)iADSR[0] = 4;
    if (keych[1] == keyreleased)iADSR[1] = 4;
    if (keych[2] == keyreleased)iADSR[2] = 4;
    if (keych[3] == keyreleased)iADSR[3] = 4;
  setPWM(); //#5
  //update FM decay exponential
  FMexp[0]-=(long)FMexp[0]*FMdec[0]>>16;
  FMexp[1]-=(long)FMexp[1]*FMdec[1]>>16;
  FMexp[2]-=(long)FMexp[2]*FMdec[2]>>16;
  FMexp[3]-=(long)FMexp[3]*FMdec[3]>>16;
  setPWM(); //#6
  //adjust the ADSR envelopes
  for (byte ich = 0; ich < nch; ich++) {
    if (iADSR[ich] == 4) {
      if (envADSR[ich] <= ADSRr[ich]) {
        envADSR[ich] = 0;
        iADSR[ich] = 0;
      else envADSR[ich] -= ADSRr[ich];
    if (iADSR[ich] == 2) {
      if (envADSR[ich] <= (ADSRs[ich] + ADSRd[ich])) {
        envADSR[ich] = ADSRs[ich];
        iADSR[ich] = 3;
      else envADSR[ich] -= ADSRd[ich];
    if (iADSR[ich] == 1) {
      if ((0xFFFF - envADSR[ich]) <= ADSRa[ich]) {
        envADSR[ich] = 0xFFFF;
        iADSR[ich] = 2;
      else envADSR[ich] += ADSRa[ich];
    tch[ich]++;
    setPWM(); //#7-10
  //update the tone for channel 0
  amp[0] = (amp_base[0] * (envADSR[0] >> 8)) >> 8;
  inc[0] = inc_base[0];
  FMamp[0] = FMa0[0] + ((long)FMda[0] * FMexp[0]>>16);
  FMinc[0] = FMinc_base[0];
  setPWM(); //#11
  //update the tone for channel 1
  amp[1] = (amp_base[1] * (envADSR[1] >> 8)) >> 8;
  inc[1] = inc_base[1];
  FMamp[1] = FMa0[1] + ((long)FMda[1] * FMexp[1]>>16);
  FMinc[1] = FMinc_base[1];
  setPWM(); //#12
  //update the tone for channel 2
  amp[2] = (amp_base[2] * (envADSR[2] >> 8)) >> 8;
  inc[2] = inc_base[2];
  FMamp[2] = FMa0[2] + ((long)FMda[2] * FMexp[2]>>16);
  FMinc[2] = FMinc_base[2];
  setPWM(); //#13
  //update the tone for channel 3
  amp[3] = (amp_base[3] * (envADSR[3] >> 8)) >> 8;
  inc[3] = inc_base[3];
  FMamp[3] = FMa0[3] + ((long)FMda[3] * FMexp[3]>>16);
  FMinc[3] = FMinc_base[3];
  setPWM(); //#14
  //update counters
  tch[0]++;
  tch[1]++;
  tch[2]++;
  tch[3]++;
  setPWM(); //#15
Right now, I'm trying to tie each keypress with a short animation like the one below.
#ifndef _SPACESHIP_H
#define _SPACESHIP_H
#include <Wire.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
// interval between the animation frames
int frame_delay =70;
const unsigned char Frame1 [1024] PROGMEM = {
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x24, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x22, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x20, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x20, 0x20, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x20, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x20, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0a, 0x00, 0x20, 0x04, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x20, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x20, 0x20, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x20, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x22, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x01, 0x24, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x60, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x01, 0x28, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x22, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x20, 0x20, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x20, 0x10, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x20, 0x04, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x20, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x20, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x20, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x20, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x23, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
// 'Frame1'
const unsigned char Frame2 [1024] PROGMEM = {
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xf0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x28, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x10, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x10, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0x00, 0x10, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x11, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x40, 0x08, 0x09, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x10, 0x08, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x04, 0x08, 0x21, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x65, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x25, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x18, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x60, 0x08, 0x09, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x10, 0x00, 0x08, 0x05, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x14, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xb0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
// 'Frame2'
void SETUP() {
  //if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
    //Serial.println(F("SSD1306 allocation failed"));
    //for(;;);
  // Show initial display buffer contents on the screen --
  // the library initializes this with an Adafruit splash screen.
 // display.display();
 // delay(2000); // Pause for 2 seconds
void SpaceshipLoop()
{display.clearDisplay();
  display.drawBitmap(0,0,Frame1, 128, 64, 1);
  display.display();
  delay(frame_delay);
  // Frame2
  display.drawBitmap(0,0,Frame2, 128, 64, 1);
  display.display();
  delay(frame_delay);
#endif
I tried using if and while statements to trigger an animation for pinD0 but whenever it is triggered, the program stops producing sounds from the other pins and does not display any animations.
Any idea why this might be?
Yes. The synthesizer needs to calculate your waveform in real time.
Meanwhile, your animation technique relies on delay() for its timing. delay() means nothing else happens. Time is spent. Wasted some might say. But no other computations or processes like your synth are performed.
a7
Third cross post.
Which Arduino are You using? D0 and D1 are connected to the USB interface on some Arduino. If so, use another digital output.
Not good manners, no good behaviour.....
I am using the Arduino Uno Rev3, I'll try what you suggested, thankyou!
Thankyou!
On an UNO, don't use D0 or D1 unless You know how to do it.
