How can I use a const __FlashStringHelper with a char
Hello all
In some case, I usinf a fonction to display a text for debuging.
I call in that way:
sprint(F("Buz"),2);
The second parameter is use to eigher Display in Serial Monitor (0), write into a SD card (1), or both(2)
here is the fonction
void sprint(const __FlashStringHelper * message, int logToSd)
  if(logToSd == 0 || logToSd == 2)
    SerialUSB.print(message);
  if(logToSd == 1 || logToSd == 2)
    #ifdef LOGGER
      sd_write(sd_logFile, message);
    #endif
And here are the function to write SD.
The below function. The problem is, the below function does not accept __FlashStringHelper (for the text)
void sd_write(char * fileName, char * text)
  //SerialUSB.println("*c*");
  sd_write(fileName, text, false);
void sd_write(char * fileName, char * text, bool ln)
  #ifdef LOGGER
    if(isSdReady == true)
      digitalWrite(PIN_SDLED, HIGH);
        logfile = SD.open(fileName, FILE_WRITE);
        // if the file opened okay, write to it:
        if (logfile)
          sprint(F("Writing ["),0);
          sprint(text,0);
          sprint(F("] to "),0);
          sprint(F(fileName),0);
          if(ln == true)
            logfile.println(text);
            logfile.print(text);
          logfile.flush();
          // close the file:
          logfile.close();
          sprintln(F(" => Done."),0);
          // if the file didn't open, print an error:
          sprint(F("\nError opening "),0); sprintln(fileName,0);
      digitalWrite(PIN_SDLED, LOW);
      // delay(100);
  #endif
Is there a way to craete a function as described here (see comment)
void sd_write(char * fileName, const __FlashStringHelper * text)
// CONVERT HERE the const __FlashStringHelper TO BE USE BY text
Thank a lot
Look at how Print.cpp manages methods that take FlashStringHelper arguments.
